2005 GTO LS2 alternator wiring? (pictures included)
So I have a alternator from a '05 GTO LS2 motor that I'm going to use with my new harness from GM for the new LS2 x58 wheel motors. I've got a 2-pin plug on the alternator, but a 4-pin plug on the harness. Also the 4-pin plug on the harness only has one wire in it. I've got a plug for the alternator, but what wires do I need to the thing?
I had the same problem with my 05 gto ls2, my speartech harness didn't fit either.
I sold the 05 alternator on ebay a bought a f body one from autozone around
$100, I also had to buy an alternator brace from an fbody, got from gmparts direct
and good to go works fine
i also have the same problem
it wasn't charging yesterday and completley died, so i wanted to remove the alternator, and found out that the 4pin connector has only one wire in it
and the problem why it wasn't charging is that the 2pin connector was totally disconnected !!
i will install the alternator again today, connect the 2pin and check if it will work with 1wire-4pin connector (coz i think it was working this way all those years )
LS1Tech Sponsor
That alternator is used with the E38 as well as some other Gen III trucks/GTOs. When used with the trucks it uses a battery control module which is a separate module that plugs in-line. With the 58x E38 I believe both wires go back to the ECM.
Jon
Jon
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
The F-body single wire that you have goes to the lamp in the cluster, or you can wire an in line resistor (to substitute for the lamp) and that's it.
Sent you a PM...
Help needed
I have a new LS7 with an E38 ECU and I found that when the new 145amp GM alternator was connected to the ECU via the two wires (Orange and Grey) the 5 volt reference was being dragged down to 3 volts which stopped the fly-by-wire throttle from operating.
As soon as I disconnected the alternator plug the problem went away!
And so after miuch complaining I eventually got a replacement from the supplier, but this time the alternator supplied was much smaller Bosch unit and only rated for 100 amps. That is bad enough, but at least the plug is the same 4 wire size so got to fitting the weekend.
Then I find that the alternator is not charging... the 5 volt issue I had originally is OK, so I suspect that the first alternator has taken out the circuit in the ECU?
Any thoughts and help would be most appreciated.
1. Do I stop using the ECU connection and do something else, in which case what?
2. Anything I can check with the ECU?
BTW this LS7 is oin an Ultima.
cheers
Keith
cheers
Keith
cheers
Keith
cheers
Keith
So I also have an 05+ alternator (two wire) with a 4 wire connection on my harness. Who sells the pigtail to plug into the alternator? or the "module?" any help would be appreciated.
