Chevelle throttle cable
Old 02-26-2008, 11:02 AM
71chevellels1's Avatar
Default Chevelle throttle cable
What cable do i need to run for 71 chevelle with 99 LS1? Will the stock ls1 f-body cable work? Thanks
Old 02-26-2008, 11:35 AM
rockytopper's Avatar
I used a lokar. Cut to fit very easy to install.
Old 02-26-2008, 11:58 AM
67rsss's Avatar
The Lokar is a nice piece, and not very expensive.
Old 02-26-2008, 12:04 PM
stealth71's Avatar
Lokar x3.
36" and I cut some off.
LOK-TC-1000LS1
Old 02-26-2008, 12:14 PM
bczee's Avatar
Lokar X4 like everyone else..
I just used an existing hole (it was square) that was in the firewall and inline with the pedal. I used a few larger washer on each side and bolted down the jam nut, ran the cable though the pedal eyelet.. then into the Lokar cable case and up to the Throttle Body and it was done.. (some cutting of the cable as needed) !
Old 02-28-2008, 08:04 PM
Brer Rabbit's Avatar
Default I had the same question!
I love finding the information u need when u need it. Thanx guys.
Old 02-29-2008, 07:26 AM
LS1MCSS's Avatar
X5 on the Lokar.
Old 02-29-2008, 08:43 AM
oange ss's Avatar
i will be using the stock Camaro/Firebird cable..
Old 02-29-2008, 09:24 AM
bczee's Avatar
You can use the stock F-Body Cable as long as it reaches ok... I think others have used them.
Old 02-29-2008, 09:51 AM
deeloc1's Avatar
What is the part number on the Lokar throttle cable? They have a universal one and a ls1 one? Which one did you guys use?
Old 02-29-2008, 10:03 AM
bczee's Avatar
I used the #1000LS1 cable...
http://www.lokar.com/product-descrip...hrotcables.htm
Old 02-29-2008, 10:06 AM
72ChevelleConv.LS1's Avatar
I used a ford torus cable and built a bracked for it to fit the intake. got the cable for free!
Old 02-29-2008, 10:38 PM
ryanvv355's Avatar
I've heard express van cable is a drop in as far as length
Old 02-23-2012, 09:21 PM
98mm 72chevelle's Avatar
do you still have the turbo hot side. tex me 501-563-3950
Old 02-23-2012, 10:39 PM
flywheel's Avatar
Lokar X? six I think..... on my 71.....
Rick
Old 02-23-2012, 11:54 PM
bczee's Avatar
Ok.. I used Lokar on my 71' Chevelle and now on my 71' Nova.. It worked well on the Chevelle.. should work good on the Nova too !
Quick Reply: Chevelle throttle cable
