pictures of my LS1 swap into 1967 nova SS
#61
Know how you feel man im in central Florida and ever since 2004 we just expect to get by at least one hurricane if not more. Good luck with cleanup hope you faired ok and just have to clean up.
#63
well the painter is coming monday to paint the firewall with his gun and some left over paint he's got. working on that and coating the a-arm with the por-15 stuff getting them ready for paint too. still waiting on the frame, most likely i will get it back this week. then its time to start putting it together and see if i can find the piece's for everything because i have them all over the place.
#65
well, went and picked the frame up today at noon and could not wait to get home to put it together. going to start coming together fast now. i left the coil springs out, and for some reason i thought the shock would hold the car up a lil. WRONG it went all the way down were i can just stick some fingers between the ground and the frame. looks cool as h#$L... SITTING THAT LOW. the front of my car will sit low now for sure, after seeing this. the coil springs and the front core support is the last of the powder coating. here is some pic's
#66
getting there. I cut some PVC tubes 3/4" about 4-5 inhces long and ran the shokcs through them to keep the car up in the air. You more then likely won't be able to get the springs in until you have most of the weight in the front of the car.
#67
I am doing a similar swap, well 2 of them. I have a 66 sedan thats getting a Checkered Racing front clip and 4-link. It is getting a 402 LS1 with a T88 on it and a 6-speed. The other is a 67 wagon that is getting a 434 LSX with a nice shot of juice. It will also get a Checkered Racing front end and already has a completely redone stock rear. Good luck with the build and keep us posted. I have also been watching on Steve's Nova Site, but I can't post there yet.
#68
i got a lil more done in the four days i have been off. got the fenders on and the front core support. the core is still in mach up stage, it needs to be powder coating along with a few other things. got the computer box made, from an army shell box that will go on the pass. side fender, that will also need coating. got the p/s hoses all made up and the adjustable valve in place. started on the bottom radiator support bracket. still dont know what iam going to do for the top. i think i got the trans. cooler mach up in my head. so it's get close. i got the wiring from the stock front end and reworking it. so i got a lot done while i was off.
#70
#72
i got the coil springs in, radiator top bracket done. more on the computer brackets. if you can see on the pass side, the green tape is where home is going to be for it. just farting around with it. got her out in the sun light a lil. got one of the headers in. air cleaner in.
#74
got the last of powder coating back today. just trying to get all the lil parts. i got the brake hard lines, alternator, belt, oil filter, 2 oxygen sens, relays, and some gauges. auto meter ultra lite's, got the speedo, volt, and water. still need the fuel level, tach, and oil press.
#75
updates
ok here they are boys. i have got all my AN fittings. the front brake lines are done. heater core hoses are done. fuel line under the hood is done. painting the hood hinges. painting the head light support brackets, or what ever you call them. fenders are on and alined some what. the computer is in place. still need to wire in the computer. headers are in with the O 2 sensors. painting the flaming river column, did not get a before picture. but will get and after picture. you can see the bracket under the dash that holds the column and thats it. soooo! here's some picture
