Tubular K member for 69 Chevelle?
Re: Tubular K member for 69 Chevelle?
Sure, all you are doing is replacing the crossmember with light weight parts. A friend of mine is doing a LS1/4L60 swap into his 69 Chevelle and we are trying to find as many ways as possible to lose weight. Hell he is lucky he only weings about a 120 so it all has to come off the car.
Later,
Bart
Later,
Bart
Try Hotrods to Hell as I know they have a A arm kit and do custom suspension stuff. Or maybe Jim Meyer Racing . One more Fatman Fabrications . I didn't see any of those list them, but it would be worth a call. They might could do one or know who does.
I got the Fatman kit for my '68 Chevy Stepside and I'm really happy with it. I got the stage III kit which is crossmember, tubular/polished Mustang II a-arms, Carrera coil overs, spindles, GM rotors and calipers, rack and pinion etc. Have to drill 4 holes and make two welds.
No, think about it this way. The front suspension/brakes and the engine bolt to the crossmember (K member). Then the crossmember bolts to the frame. All you need is a tubular setup that will accommodate those three requirements.
Later,
Bart
Later,
Bart
9 Second Club/LS1TECH Sponsor
Many probably didn't realize that the crossmember bolted to the frame on the Chevelle (I know I didn't).
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
