New LS Swap book- Need some pics
Old 04-15-2008, 12:08 PM
71buickfreak's Avatar
Default New LS Swap book- Need some pics
Hello all,
I am in the process of writing an LS swap book for CarTech Books. I am looking for some unique cars to feature in the book that have completed and in progress swaps. I need hi-res images for the book. If you have a project that you would like to be considered for the book, please send me the following:
Lead shot of the car (shrunk pics for email, will get hi-res when chosen)
build up story- include why you built it, when and how. Please mention interesting stories such as difficult parts of the build, failures, successes, etc. Basically things that would be helpful\interesting to the readers.
List of components used in the swap
List of available pics of the vehicle. I would like to have in-progress pics as well as completed pics. The cars do not have to be finished, an LS sitting in the frame of a Volvo or Crosley is pretty cool, and might be book worthy. That said, I have plenty of Camaros with LS engines. Sorry, I don't need anymore. But if you have a Merc with an LS7, I want to see it.
Please don't prejudge your car, I want a large pool to select from. I have limited space and can't choose them all, but I need 10-14 cars. I need some unique install shots as well. If you built your own crossmember and motor mounts, let me see 'em.
If you have LS-swap products for sale (or know someone who does) send me that info too, this will be the best opportunity to get some serious exposure for your parts.
Thanks,
Jefferson Bryant
Jefferson@bryantmedia.us
Old 04-15-2008, 12:36 PM
rao
rao's Avatar
That sounds like a neat book. If I had the time to write a chapter on mine I would do it and send it to you
Old 04-15-2008, 02:04 PM
Default book
I was hoping to get some pics on your M3. Any chance of that?
Old 04-15-2008, 02:13 PM
z28evans's Avatar
I've got photos of the build up and racing of an 89 IROC, 94 RX7, 89 240SX, and a 86 El Camino that we went racing with.
Many photos here: www.z28evans.com/album & www.bubbadrift.com/album/
James
Old 04-15-2008, 02:37 PM
Did you build the crossmember for the RX7 or is that a kit?
Old 04-15-2008, 02:43 PM
bczee's Avatar
If you want to take a quick look at my Chevelle, it can be viewed on my CarDomain site. Use the Link in my Sig..
If you then want more information.. I can then will provide.
Old 04-15-2008, 02:51 PM
pcmcobra's Avatar
can't wait for the book!
Old 04-15-2008, 02:53 PM
LS1 Coupe's Avatar
48 Chevy FleetMaster Coupe, Soup to Nuts, Still in Progress, Pics are Here.
https://ls1tech.com/forums/conversions-swaps/777355-ls1-48-chevy-coupe.html
Old 04-15-2008, 03:42 PM
classic gary's Avatar
I hope there is going to be a chapter on manual trans besides the usual T56. Something like TKO 500/600, Muncie, Richmond, ect. There is lots of "scattered" info out there, and not all of it is, well, correct.
Old 04-15-2008, 04:00 PM
rockytopper's Avatar
This guy deserves his on chapter in the book
https://ls1tech.com/forums/showthrea...443&highlight=
Old 04-15-2008, 04:07 PM
Stu Cool's Avatar
Check out the project journal for my Custom '53 Studebaker with LS1 described and linked in my signature. I have many more photos than those posted on the hotrodders.com
I'd be glad to participate and our car is pretty unique.
Pat
Old 04-15-2008, 04:14 PM
LS1TECH Sponsor
Carshopinc.com's Avatar
Email sent with some info...... If you have any other questions we would be glad to try and help.....
Thanks
Carshopinc.com
Old 04-15-2008, 04:15 PM
rao
rao's Avatar
Sure, I will send you an e-mail.
Old 04-15-2008, 04:42 PM
bczee's Avatar
FYI... I have seen Pat 53' Studebaker .. very good work.. +1 for his on checking it out..
Old 04-15-2008, 06:01 PM
Shawn MacAnanny's Avatar
I'm the "it's good enough" back yard guy who built his engine in his dining room and installed the engine and trans in is lawn on plywood haha. I was able to modify the TH400 crossmember to work
Modified crossmember, unpainted, but you can see the welds and such that need to be cut
https://ls1tech.com/forums/attachmen...1&d=1207789415
Engine install on plywood
https://ls1tech.com/forums/attachmen...0&d=1207789415
Old 04-15-2008, 06:08 PM
1BadAction's Avatar
Check here, 93 fullsize blazer 4wd. Will have more pics up soon, its a work in progress right now so any pictures in particular (like one of the notch in the frame where the AC compressor sits) I can get them.
Old 04-15-2008, 06:17 PM
Slvr00Bird's Avatar
Swapped my LS1 into my stock V6 00 Bird... nothing anyone would want to read about though probably...
except the startup was kind of suspenseful.. it was only running on 6 cylinders until I pounded its *** a little and all 8 kicked in and about ripped my head off.. lol..
Old 04-15-2008, 07:08 PM
68shortstep's Avatar
check out here for the 71 chevy truck i did for member killer71
http://67-72chevytrucks.com/vboard/s...d.php?t=244448
Old 04-15-2008, 08:19 PM
v8mazda351's Avatar
www.racingconcepts.net
Old 04-23-2008, 02:24 PM
anybody with more better info, speak up.........
I have t56 and TKO stuff, but nothing really on the richmond or older GM manuals. You said that a lot of what is out there is bogus, do you have some insight on that you could share?
my response:
I've heard everything from, use a stock ls1 flywheel and clutch, to "special" flywheels and clutches, to the Gen 1 bellhousing can't be used because of the "different bolt pattern" to.............what ever. Here is what I ws able to do, and pics in my siggy.
I BOLTED a 1957 Chevy cast iron bellhousing to a 5.3 and then bolted a TKO 500 to it and used the "special" pilot bearing that GM sells, (it's an alternator bearing). Everything bolted up. THE ONLY thing I didn't get to was the flywheel. I'm not spending 300.00 each to compair a stock LS1 f-wheel with an aftermarket f-wheel. But GM has a specific flywheel for old style, read that Muncie/Saginaw, tranny use. Again $300.00. So I stopped, and am going Cadillac 500 power.
Quick Reply: New LS Swap book- Need some pics
