98 Vette LS1 into 66 Skylark first test fit
Well, the first test fit has gone well so far. The A/C compressor hit the K frame and had to be removed. The rear coil on the drivers side is very close to the brake booster. But, all in all, it went well. In the attached pics, it is bolted to the trans and sitting on the mounts. I still have to test fit the Edelbrock retro fit headers. Hope they slide right in!
Yes, I am running BRP mounts and the hummer oil pan. The oil pan does hang a little lower than the crossmember. Several companies offer smaller dual diaphragm brake boosters and I will probably go to one in the future. Right now, I just want to get it in and up and running. Good luck with your project!
Thanks for the info on the boosters. I will look around for something after I get the car up and running.
Corey, I will try to remember to get pics of the oil pan tomorrow. That is when I plan to test fit the headers.
Thanks for all of everyone's help. This site rocks!
Pics of the oil pan and header fit. The oil pan hangs about 1.5 inches below the k member. The sump is about 4 inches behind the k member so a pan with a shorter (depth) longer (front to rear) sump would have worked.
Mounts welded in
Got the mounts welded to the frame today. When I went to lift the engine back out, the trans hit the tunnel before the engine mounts cleared the frame stands. Had to remove the engine mounts to get it out. Gonna be real fun to put back in.
98 Vette LS1 into 66 Skylark Update
Haven't posted in a while but I have been making some progress. Engine has been in for test fit and out to clean up the engine compartment. Here are some pics of the progress to date.
looking great man! You are beating me by far. I'm still gathering all sorts of other parts like my hydroboost kit, disc brakes all around, diff, tubular control arms, etc. Do you think you could have moved the engine further forward and gotten the air to work as BRP advertises?
