Pair of interesting swap adapters...
Old Feb 22, 2009 | 07:42 PM
S10xGN's Avatar
Default Pair of interesting swap adapters...
From Speedway no less...
Russ
Old Feb 22, 2009 | 08:06 PM
bczee's Avatar
Look like a good product if you want spend the money. I took a stock LS1 oil sensor, broke the plastic part off, drilled and taped it for 1/8" NPT and it does the same as those, just doesn't look as good, but then I can't see it in place anyway.
Old Feb 22, 2009 | 10:20 PM
luckyhenriksen's Avatar
Looks like a nice piece. Anyone have experience with them?
Old Feb 22, 2009 | 10:32 PM
bgblockelcamino's Avatar
have bought quite a few things from speedway. great source for oddball stuff.
Old Feb 23, 2009 | 12:36 AM
thunderstruck507's Avatar
I just drilled and tapped the little removable cover that goes above the oil filter.
What I really need is an adapter to use my stock temp sending unit. I see they have one to adapt to a 1/8th unit, but mine is larger. I really need to find a way to make it work or find a 1/8" sending unit that will work with my factory gauge, I don't like not having a temp gauge.
EDIT: as far as experience with speedway, they are great, that's where I got my front springs and height adjusters
Old Feb 23, 2009 | 05:42 AM
Pop N Wood's Avatar
I bought a similar one from equus for my oil pressure sensor. Two bucks less and comes with 4 adapters, including a water temp one. The water temp one is pretty worthless unless your temp sensor is 1/8 npt.
http://www.autobarn.net/eqoilpreselt.html
Couldn't see drilling out a $50 oil pressure sensor to save $8.
Old Feb 23, 2009 | 10:05 AM
garys 68's Avatar
Bought both water and oil adapters. Nice pieces, got them in a few days, no problem.
Old Feb 23, 2009 | 11:20 AM
Stu Cool's Avatar
+ 1, I was able to adapt both from this kit.
Old Feb 23, 2009 | 03:39 PM
five7kid's Avatar
I bought a 3rd gen f-body aftermarket cluster from a member that had the water temp adapter with it. I went to install it Saturday, as it just started to snug up I felt it give and backed it out, thinking I had stripped the threads of either the adapter or head. Both looked fine, so I tried again and this time the threads broke off of the adapter in the head.
I went ahead and ordered another (from Summit), guess I'm a glutton for punishment. But, the other one was used. . .
