Old Apr 25, 2016, 05:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
Differences in versions of 4L60E's
Old Oct 8, 2019 | 07:56 PM
  #61
Stacy R. Nix's Avatar
Default Looking to put Ls1 out of corvette in my 2002. Camaro v6.
Looking to put Ls1 out of corvette in my 2002. Camaro v6. Can I use my transmission and what do I need to do. Please email me Sz71nix3@gmail.com. Thsnk you. Stacy Nix
Old Oct 8, 2019 | 09:01 PM
  #62
Your tranny will not fit on the V8. Different bellhousing
Old Mar 10, 2025 | 12:21 AM
  #63
Grant 99 z71's Avatar
Default 99 4l60e swap to 02 2wd
My 99 has a 4x4 4l60e, is it possible to the the transmission out of my 02 2wd single cab (has a 5.3l and 8 bolt rear axles) but the motor is 5.3l so im assuming it will bolt up to my other 5.3l. Considering i have the whole parts truck im hoping i can use everything from the donor truck. Any suggestions or help is greatly appreciated.
Old Mar 10, 2025 | 12:32 AM
  #64
You're not too clear about what you are doing. Are you replacing the engine or the trans?
Old Mar 10, 2025 | 05:20 AM
  #65
garadyy's Avatar
Different Bell Housing.
(Incorrect, see next post.)
Old Mar 10, 2025 | 10:17 AM
  #66
You're referring to the original poster's issue. Try again....
Old Mar 10, 2025 | 12:12 PM
  #67
mrvedit's Avatar
Moderator
@Grant 99 z71 First welcome to the forum. Next, in the future please do not post on threads that have been dead for a year or more.
Now to answer your question:
The output shaft of 2WD and 4WD 4L60E are totally different and the transmission has to be extensive disassembled to swap output shafts.
Considering you are talking about 20+ year old transmission, I am certain that even the '02 should to be completely rebuilt. The input shaft seals will likely tear, same with gaskets and frictions are likely 90% worn out, with many internal leaks.
IMHO, it would be better to sell your 2WD trans and use the money toward a 4WD 4L60E, any year between '98 and '06 will work, later years are better. Just make sure it is a 300mm trans from an LS engine.
Old Apr 22, 2025 | 10:16 AM
  #68
RNovr's Avatar
I have a 1999 Yukon with an Lt1 with 4x4 transmission and I want to put in a 4L60e from a 2003 gmc, which is also a 4x4. Would that work?
Old Apr 29, 2025 | 05:40 PM
  #69
mrvedit's Avatar
Moderator
No, it will not directly/easily fit. The torque converter will hit the LT1/SBC crank about 3/4" before the bell housing is flush with the engine block. GM makes a spacer, but it costs $500, or a custom torque converter will likely cost $1000. This assumes the 2003 GMC is using a 300mm LS compatible 4L60E. You will need an older 298mm version of the trans.
Here is my detailed (and Sticky) thread on the subject:
https://ls1tech.com/forums/automatic...s-spacers.html
