4.8 + 5spd 4X4 into 3rd gen
'01 4.8l LS series vortec + a 5.3 M5 4X4 transmission into a '85 Z28
Will I need a '01 harness or is painless the best way to go?
Can a 4x4 transmission be used in a RWD application or do I need a 2WD tailhousing?
tell me what I need, thanks
sawzall wielding director
You will need a 2wd tailhousing and most likely have to change the output shaft (I know for the auto transes the output shaft is different from the 2wd/4wd so I would assume the manual would also have 2 diff output shafts)
For the wiring you could go either way
