04 gto alternator in LS1Miata - need help
Does anyone know how to wire in an 04 GTO alternator into a 2000 Miata?
I'm in the final stages of my LS1Miata conversion and the alternator isn't charging the battery. As I look into it; it appears the Alt is controlled by the PCM, but I don't see any pinout points that would work.
Any thoughts & suggestions is appreciated.
Thanks, Ray
Thanks, Ray
If your using the gto pcm, alternator is seperate from it. Like the 98 camaro I believe. White wire goes to 12 volts battery and brown wire goes to a dash bulb or a 470 ohm resistor then 12 volts iginiton.
