harness wires
My personal thresh hold is 1.2ohms. Beyond that, I cut the section out and redo it. As a point of reference, an unbroken 5' 20ga wire with OEM crimped on PCM terminal and sensor terminal on the other end is usually .7-.9ohms. For most sensors this isnt a big deal, but some are resistance based, such as the TPS. Then the bad solder joints will cause faulty readings and the PCM will over/under compensate the actual throttle position
Engine bay wiring is TXL jacket stranded. Several sponsors on the board sell it by the foot. I like to buy in 500' rolls from ebay. Youll build 98% of the harness using 18 and 20ga wire. Fuel relay to pump is 14ga, most relay 12v and engine grounds are 12ga
Good luck
As I'm thinking right now;
1000 feet each of 18 and 20ga.
500 each of 14 and 12ga.
and around 500 feet in multiple sizes of black (ground) wire.
Does that sound like enough, or am I going to need to budget more?
Thats engine, dash, interior, front and rear light harnesses
Wire is expensive, price out 500' of 12ga
. can you do mine too .I have an 05 harness with ecu
