07 trailblazer ls2 into 00 fbody questions
I have come across a 07 trailblazer ls2. From the reading i have done i understand i need to change the intake which is fine i wanted to go fast 90/90 set up and pulley systems. I was wondering if i can use the alternator bracket from my ls1 on the ls2 and if i can keep the tb alternator. also can i use my pulleys off the ls1 and put them on the ls2. Also is there any other things that i need for the conversion. And can i connect it to the computer that is currently in the car? any help would be greatly appreciated.
The tbss alt will fit the fbody alt bracket. All of the accy drive pulleys will bolt up to the ls2 without any hassle. You CAN NOT use the 00' computer because its setup for 24x reluctor and the ls2 has the 58x reluctor.
