Camshaft suggestion for Carb'd 5.3
I'm Running (for know) a stock 5.3L Longblock w-Edelbrock Perf.RPM and Edelbrock 600 CFM carb.
200-4R trans w-2400 stall converter.
3.73 rear gears w-26 inch tire
It's going in a 71 Chevelle and will be a driver. looking for a cam with broad power band.
Was looking at Comp Cams XR273HR for good power and drivabilty.
Suggestions?
"I would use our part number 54-426-11 in this setup. This is a 3 bolt camshaft. There is not much difference in selecting a cam for a EFI or Carbureted LSX engine. They still typically like a little wider LSA and typically either a 111 or 112 for a carb setup are best. This is completely dependant on application though of course.
Aaron Mick
COMP Cams Technical Consultant"
I would consider Comp Cams as good of expert advice as I might find on this topic. So, for me, it is case closed. I will be using a good old off the shelf XR275HR.
