A body motor mounts/adapters ratings & opinions
I spoke with MAST a few days ago. They said the oil pan is still 6 months away IIRC
So, I will hold out on the pan as long as I can. But, when I am ready to put this motor in, I will have to buy the best pan that is available at the time. Right now, for a 64 to 65 A-body, that pan appears to be the JZ Motorworks piece.
Has anyone dropped an LSx on top of the Skylark frame mounts to see if they could be used?
I saved the CAD drawing for making your own mount adapter plates. It seems pretty easy to drill the mount holes where ever needed.
Does having the motor mounts located farther back interfere with the exhaust or starter?
I'm looking into the feasibility of a 5.3 swap into my '64 Sportwagon.
Motor mounts andoil pan.
Check out my build post titled "LSX swap into a 1964 Chevelle L98 4L70e" on this forum. I have pictures about the Moroso pan I used. Had to dimple it a little with a hammer but nothing touches now. As for headers on a 1964, I tried the Hookers and Doug's - neither fit. Edelbrok's fit great. See my pic's on the whole build.
I am still looking for a solid idea on motor mounts for my 69 Chevelle. I have searched and searched. I have the JZ Motorworks pan and I am using my powerglide in the factory location. I cant find anything on this. I may just make my own at this point!
Dan-O
Dan-O
#32
Lots of reasons. It was stock in my car, cheap to build, strong, less shock on the tires, light weight, and most of all because it runs great on the street/track. I guess we will see what happenes with the 6.0 in front of it. Maby the worst thing ever! I might do a 4l60 later so I can have OD.
Dan-O
Dan-O
