Are 4L60E year specific? I have an '06 LQ4 that I'm trying to find a 4x2 transmission for. My understanding is that any 99-06 transmission will bolt right up with no issues. Is that right? Motor originally had a 4L80E 4x4 bolted to it. Are the internals the same on the trannies that were used on the 4.8 and 5.3 motors? |
The wiring is different between the 4L60E and 4L80E. If you have the "short crank" engine they are a bolt in swap as long as you have a transmission from a Gen III / IV engine. If you get a V6 variant the input area is different and is setup for the depth of the old Gen I / II small block and will require a spacer on the crank snout. Happy hunting. |
Thanks for the clarification. |
Even better thought would be to find a 4l65e from a 4x2 truck(03+) then you dont have to worry about fitment issues, and its built stronger than the 60e. |
Originally Posted by deuce4935
(Post 14321205)
The 65e is built with better internals than the 60e. Some guys are rebuilding the 60e with 65e internals for better strength. |
© 2024 MH Sub I, LLC dba Internet Brands
