Blueprint Engines 427 crate motor - a good buy?
Isn't this a pretty good buy for a close to 600 hp LS motor kit?
http://www.summitracing.com/parts/MLL-PSLS4272CTF/
From all the LS crate motors I've seen out there, this one seems to be the most complete for this type of power level. ECU w/tune, harness, oil pan, coils, DBW throttle, it's all there...
I know this isn't a LS7, but how high do you think you can safely rev this motor considering its longer stroke and likely less heavy duty valvetrain?
I think my question is more along the lines of "how does this compare to other crate motor alternatives" (be it GMPP or others). Sorry if I wasn't very specific.
If you want to go naturally aspirated...and get a really good warranty..you can go with the GM crate. If you wanted or could do the leg work your self,you could build a 5.7 or even 6.0 to meet that hp goal..for an easy 4-5k turn key..[rough guess] If you go boosted...you could use a stock 5.3 and get easy streetable 550-600 on pump gas and be well below the 10k.
Well I would asked how do they arrive at 427 cid with there ALUMINUM LSx 427, Since it appears they do it with an LS3block and looong stroke, they need to spell out the rev limits pretty clearly for this 427, the parts list and the fine print (or lack of in the case of the fine print) in the Warr. is the true tell.
A buddy once told me (Mike @ CMS) Performance needs to be looked at like a 3 legged stool of Performance-Cost and Reliabilty skimp on any one too much and that stool falls over..
By the order of cost
1 Build it your self-the labor is free right
2 Talk to some sponsors here about building what you want-you'll pay more but get what you want.
3 Buy a GM crate that makes the hp your looking for $$, thats what I did found because I found a deal from a sponsor. (See Below)
Just gotta look around some....good luck
10% http://www.couponsnapshot.com/coupon-detail-452656.html
15% www.summitracing.com is having a sale until Thursday 1/5/2012
Place any order that is over $500 and you enter coupon code ZSJA15 and get 15% off!!!!
I'm doing a Darton sleeved block from RED and I think with good shopping you can do much better. LS2 block with RED installed Darton sleeves. 4.125 bore and 4.00 stroke. No worries on piston rock.
Just my .02
Just my .02
You can run a 4.250 stroke if its done right
I would avoid blueprint engines completey! The outfit that builds these is local to me, Marshall engines in Kearney Nebraska. They have a hard time even selling anything local!! Most of the time as a truck load of new motors go out, 2 truck loads of warranty motors come back in.
Google up blueprint engine warranty, grab a few beers and prepare to read a while....
You have been warned.....
T,
