72 c10 LS6 can't keep running
Old Jan 18, 2012 | 09:01 PM
SamH's Avatar
Default 72 c10 LS6 can't keep running
Hey guys! I'm new to site an ls swap so bare with me. I have a 72 swb that I have installed an Ls6 with the entire harness, column, cluster and fuel. When I first set engine into truck I got it to run no problem. But now that I have hooked up trans, water, exhaust and grounds it only runs for bout 5 seconds. Once it runs and shuts off, it will not restart until I pull key and wait a minute.
I am able to pull up codes through vette cluster but there's a WHOLE BUNCH.
Old Jan 19, 2012 | 08:45 PM
weircc's Avatar
did u flash computer??? im pretty sure u need too remove security
Old Jan 19, 2012 | 09:49 PM
SamH's Avatar
I have done nothing but transplant Everything from the corvette to my truck. Do I need to buy a programer? I have swapped everything but 6 speed and abs. I have both fuse blocks with ignition and vats, column, cluster, water, fuel pump, cats etc. Don't understand why I need to flash???
Old Jan 20, 2012 | 10:09 AM
Shon Herron's Avatar
VATS is still working
Old Jan 20, 2012 | 11:40 AM
groundczero's Avatar
If it is not the VATS, it is another system specific to the vette called column lock. Make sure VATS and column lock are both programmed to off, I had this issue with one of my swaps when I used vette parts.
Old Jan 20, 2012 | 02:45 PM
SamH's Avatar
It did say column lock and to pull key and wait 10 seconds. Is there software I can download or buy to delete this, or do I have to take it somewhere?
