Stock Exhaust Manifolds,Chevelle
Old 03-13-2012, 07:14 AM
MINK's Avatar
Default Stock Exhaust Manifolds,Chevelle
My Buddy has started a LS project,like everyone else he is on a tight budget, headers seem to be a big expense. We were wondering what stock exhaust manifolds would fit on a 69 Chevelle with a LQ4/LQ9 ? Thanks!
Old 03-13-2012, 08:15 AM
bczee's Avatar
The Truck manifold will most likely come into contact as they are too wide. Stock 4th or 5th Gen F-Body are your best bet. Vette one will not work either. They exit too far forward (mid area).
Suggest you reseach in the Sticky's on the top of this section to see what other have already used or found not to work..
BC
Old 03-13-2012, 08:22 AM
garys 68's Avatar
98-02 F body, will clear clutch linkage too. Bought a set for $40 on CL.
Old 03-13-2012, 08:35 AM
NOS327's Avatar
I have 2 sets of '98 camaro manifolds (for sale). I fit them in my '67 over the weekend and they fit great, I assume the front stub region is similar enough to be true on his 69.
Caution that 98-99 and 00-02 are different. Besides the EGR bungs, the later ones have a big rectangular/trapezoid flange on one manifold, and it hits the frame. The older ones have a smaller flange and clear everything. Got some pictures on my phone, will try to upload over lunch, but send me a PM and I'll get you these manifolds I have at a good price.
TJ
Old 03-13-2012, 09:11 AM
NOS327's Avatar
Passenger side fits amazing, just like old car manifolds:
Driver side fits equally well, just couldn't take a picture that captures the niceness, maybe should have taken a picture from underneath. Anyway, looks like my brake lines are in the way, but they actually clear pretty well too.
and a picture basically looking down the firewall just inboard of the brake master:
The EGR ports can be tapped and plugged with NPT plugs on the super cheap. Or you can saw them off and well a patch.
For reference, this engine is installed with the Hooker standard location motor mount plates and Energy suspension poly motor mounts.
Old 03-13-2012, 09:25 AM
MINK's Avatar
This site is AWESOME! Thanks everyone!
Old 03-13-2012, 11:16 AM
99VetteFRC's Avatar
I used the truck manifolds and cut the flanges off and welded on V-Band clams. Clear great and work awsome. When I flip them for turbos it will be easy to attach.
Attached Thumbnails Stock Exhaust Manifolds,Chevelle-dscn1131.jpg   Stock Exhaust Manifolds,Chevelle-dscn1130.jpg   Stock Exhaust Manifolds,Chevelle-dscn1129.jpg   Stock Exhaust Manifolds,Chevelle-dscn1128.jpg
Old 03-13-2012, 02:00 PM
MINK's Avatar
Thanks great info!
Old 03-13-2012, 09:27 PM
LS1 pwrd NOVA's Avatar
Nos327 can u take closer pics of the difference in the manifolds? Do you have a 67 chevelle?
I fit a set of 4th gen fbody for the 66 chevelle, dont know the exact year as i didnt know there was a difference in the flange, but they fit pretty good. I think i have the bigger flanged ones but they fit. Ill ask the guy that let me test fit before i buy them the exact year of his car. This seems to be the cheapest exhaust for a chevelle swap plus the flange hole seemed bigger than the truck hole.
I tried a set of truck manifolds but they wouldnt fit on the passenger side as the flange hits the frame. Driver side i dont recall but will try again.
I tried a set of full length fbody headers, flowteck i think he said they were. The passenger side hit the frame. I couldnt get them to even bolt to the heads. Ill try again another weekend and post up. I may be able to get a set of mid length fbody headers so ill post results up when i get them.
I also have a set of 66 nova shorty/mid length lsx swap headers to try but they werent cheap at all. Only one company makes them for this car with a stock front end. They are made by stainless works / church boys racing, 1-3/4" stainless with 3" collector. They fkn sweet and perfect when i lower the nova. Im gonna see if they fit the chevelle when i get a little more time and ill post up the results with pics.
Old 03-13-2012, 09:39 PM
bczee's Avatar
One Major different are that the 98-99 F-Body are doubled wall SS tube Mainfold.. GM couldn't get the car to pass emission and one band aid was to use those tube manifolds, as they would heat up faster. For 00's, they finally got the cast manifold, tune, cats and all to meet and pass the Fed emission standards.
BC
Old 03-13-2012, 11:00 PM
NOS327's Avatar
Yes 67 chevelle. Picture is of my 2 sets of 98 manifolds... planing to use for 4 sale ad. If yourmanifolds are cast, then they are the newer ones as dude pointed out above. These are formed and welded 2 piece deals. Your egr will also be in a different location.
ps, let me jam the steering column in the car to make sure it clears..
Old 03-14-2012, 02:45 PM
It should clear as the fit my 66 chevelle and my steering is all intack. So is it better to get the 98-99 or 00-02 manifolds or does it not really matter? I thought all the manifolds were cast????? Some were stainless?
Old 03-14-2012, 05:51 PM
64chevelleSS's Avatar
Default Exhaust manifolds
Dont know if you were willing to look into aftermarket or not, but Hooker just released its new cast iron manifolds. were made to help with some of these figment problems. I am waiting on my set to go on a 64 chevelle with an ls1. summit racing or scoggins Dickey both should have them ready to ship.
$299 uncoated, $399 coated.
Old 03-14-2012, 10:21 PM
I saw those hookers and thought if worse came to worse id get them, but..... To me they do not look like they will make any more power than stock fbody manifolds will. Stock fbody manifolds are very cheap and sometimes free. $299-399 for the hookers in my opinion arent worth it. Id put more money into headers or skimp and get fbody manifolds.
Old 03-14-2012, 10:29 PM
chevellepowered's Avatar
ive have personally used an 08' truck manifolds..virtually need nothing to make them fit..i grinded 1/8 inch to to make sure it cleared ..but it cleared... i do have pics..
Old 03-14-2012, 10:31 PM
https://ls1tech.com/forums/conversio...t-boosted.html
on the first page..pics
Old 03-14-2012, 11:11 PM
Are 08 truck manifolds different than around 02 year? I tried them but i was ina rush, they hit the passenger side frame enough for me to think they wont work. Ill try again unless the manifolds are different than yours.
Old 03-15-2012, 06:50 AM
spot_55's Avatar
I used 2002 trans am manifolds,they fit great! However depending on where you locate your engine will determine wether or not you can use the front o2 sensor bung in the driver side manifold. Many say they had to plug the hole and move the sensor down in the pipe for clearance as the sensor hits the crossmember. I was able to use the stock location on my setup.(5.3 in a 71 chevelle) also tried the 2000 truck as well as 20005 truck manifolds neither set fit.
Old 03-15-2012, 03:32 PM
rallystyle's Avatar
i have 00 camaro manifolds in my 69. clears eveything
Old 03-15-2012, 05:05 PM
yes they are diffrent.. i had 99 manifolds..way to much work to get to work.. i used an 08.. as u see in the pics mentcioned above they fit..
Quick Reply: Stock Exhaust Manifolds,Chevelle
