Can I use this transmission? (pics inside)
Hi all
I was able to get a 4L60e transmission for $150, but I don't know if I can use it. I have the book "GM LS-Series Engines: The Complete Swap Manual" and I read through the whole Transmission section, and I can't determine weather or not this older style 4L60e will work.
I have a 5.3 from a 2002 Yukon (which came with a 4L60e stock) Below are the pictures of the transmission I found for $150. Notice that it is the older, single piece bellhousing. The guy said it was out of a late 90s van.
So, can I get this thing to work with my 2002 5.3?
If you want the PCM to control the transmission it needs to have PWM cast in the front pump area.
I discuss this very topic in my build thread.
There is also other information about using older (non LSx) automatic transmissions with LSx engines.
