95 ls1 240sx forsale 10k
This is a 1995 Nissan 240sx SE LS1 powered. It has a LS1 5.7 engine, 6 speed TREMEC tranny, out of a 2001 Camaro SS. It has 70k miles on the engine, 180k on the car. Everything to install the engine and get it running was Sikky parts. (Sikky motor mounts, oil pan, dip stick, oil filter relocation, sway bar, tranny mount, wire harness, master cylinder and lines, Dakota Digital box for all stock gauges to work, Sikky headers, driveshaft) It has a Godspeed radiator and duel fans hooked to hideaway toggle switch, mechanical oil pressure gauge, air fuel ratio gauge, LS6 intake manifold, port and polished throttle body, 255lph Walboro fuel pump, new Camaro battery, Camaro fuel filter, J30 rear end, 3 inch exhaust, Y pipe out the back, Brimbo drilled/slotted rotors all the way around with new break pads, GTO cold air intake, NGK tr55ix spark plugs, new bluetooth radio, new 275x40x17 NITTO NT05's on rear, new windshield (lifetime warranty to leaks), new window motors, sunroof also works. Tuned by Trahan Motorsports. Car runs absolutely awesome, no problems. Drives like a stock vehicle. Needs some TLC on the body, few paint chips here and there. A primer spot on the back bumper. Someone had a ricer wing on it and put plugs in the old bolt holes. A/C works great. A/C ran off of a toggle switch. Wires would be need to be traced out to work right from Sikkys harness. Heater works great. Needs a front end alignment (doesn't ride bad or anything, steering is just not aligned). Has a crack on the dash on top the gauge cluster but interior is a 9 out of 10 due to crack.. I have a hyperflex bushing and hardware kit for the car also, not installed. Asking $10,000FIRM Cash. Clean title. If you have any questions,email straightsideways2000@yahoo.com please text me 985-226-five five 49. http://s1179.photobucket.com/albums/...owered/240lsx/
Ha! Awesome, I'm from bayou blue! Living in Bourg now. Mitch trahan is one of my closest friends from high-school! I'm actually building his mustang. Hope to find time to post a build thread soon...
yeah, he's pretty busy now. hints the reason im going to finish the mustang for him. he told me about your car when you were starting the build. pretty clean car. what makes you want to sell it
