no tach after lsx swap dakota vhx 67 camaro
My dakota vhx steup in a 67 camarow/99 ls1 t56 psi harnessand pcu getting no tach signal. set the dakota to 5v and 4 cyl but nada, tried 8cyl and bus but zip, any clues???? thanc
You should try a pull up resistor, I had the same problem as do many others. Here is a link for my fix.
https://ls1tech.com/forums/conversio...i-harness.html
