2001 v6 a4 to ls1/t56 no power in gear
I recently swapped out my tired v6 for an ls1 t56 set up that a guy I know had sitting around. Both motor and trans were freshened before install. Motor has a tsp 228r with the necessaries for a cam swap (springs push rods new chain, high flow oil pump headers). It turns over and idles fine, actually sounds quite healthy. I was waiting on a throttle cable so i could drive it which finally came in. Once you put it in gear and give get gas it just goes nowhere. Revs up in neutral but try to move and it just falls all over itself. There's a code saved in abs c0244 pwm torque delivery malfunction. This sounds to me like traction control but the ls1 isn't set up for traction control. The body with the v6 in it was equipped with ASR but I'm not sure how everything communicates. I'm thinking it might have to do woth the v6 being electric throttle which is now cable but again I'm not sure. Any suggestions anybody?
