LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Conversions & Swaps (https://ls1tech.com/forums/conversions-swaps-28/)
-   -   Ls 69 Chevelle SS won't start? What's wrong? (https://ls1tech.com/forums/conversions-swaps/1639627-ls-69-chevelle-ss-wont-start-whats-wrong.html)
retardedpenguin Apr 15, 2013 10:28 PM
Ok I have a 69 396 SS and installed a 4.8. I converted the harness and got everything hooked up except the maf and O2's. The car has fuel, spark, proper fuel pressure and the computer tuned. With the boot undone from the coils I can hear them spark as the car cranks. With the injectors pulled, they each spray fuel cranking. The car fires but won't run, runs a second longer with starter fluid. My friend kept messing with it and when I started the car the next morning, it fired and kinda idled without dying but we never played with it. Figured it was ok and started to clean up the wiring. Went to start again and it just fires and dies as usual. Can't keep it running with fluid as it backfires through the intake.
An obd2 scanner won't connect to it. But since it was just tuned, the computer should be fine. Only a foot of wire between pin 58 and pin 2 on obd connector. I've done a swap before with the same exact issue and it turned out to just be the 3 harness grounds but on this set up I have them tied together and grounded on the firewall. Might not be the best but it did run for a little.
But yeah guys, I'm stumped. Has everything needed to run, there's just nothing else I can think to check aside from the PCM issue.
retardedpenguin Apr 16, 2013 12:32 AM
Checked for codes. 7 are throttle related and one is evap. Don't see how that would stop it.
oldgoat69 Apr 16, 2013 06:06 AM
Does the fuel pump run in the "on" position, or only when cranking?
retardedpenguin Apr 16, 2013 01:00 PM
Have it wired to ign hot run/ crank. Holds good pressure.
Joe1967ls Apr 16, 2013 02:01 PM
I would try running a grounding jumper from the engine block to the grounds on the fire wall, or just put the grounds on the engine block
© 2026 MH Sub I, LLC dba Internet Brands
