LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Conversions & Swaps (https://ls1tech.com/forums/conversions-swaps-28/)
-   -   Bob's S13 LS1 Drift Build (https://ls1tech.com/forums/conversions-swaps/1709829-bobs-s13-ls1-drift-build.html)
Badbob2121 Feb 26, 2014 10:52 AM
Well at the last drift event (Midnight Madness) at Gateway Raceway in 2013, my SR decided to give up from what I suspect to be a spun rod bearing. I ran this SR for 3 years and never gave me many problems.. But instead of rebuilding I decided to make the switch over to a new platform for the 2014 season..
My SR setup was your basic GT2871.64 setup, made great power and absolutely loved it, in a way I am sad to see it go..
http://i803.photobucket.com/albums/y...69392754_n.jpg
http://i803.photobucket.com/albums/y...ps5d2abe46.jpg
http://i803.photobucket.com/albums/y...psdb8327aa.jpg
http://i803.photobucket.com/albums/y...ps400ac6ad.jpg
http://i803.photobucket.com/albums/y...01065359_n.jpg
http://i803.photobucket.com/albums/y...ps14257eac.jpg
http://i803.photobucket.com/albums/y...31648446_n.jpg
http://i803.photobucket.com/albums/y...97151141_n.jpg
http://i803.photobucket.com/albums/y...ps321f93b1.jpg
http://i803.photobucket.com/albums/y...ps5c36db38.jpg
http://i803.photobucket.com/albums/y...ps76532e67.jpg
http://i803.photobucket.com/albums/y...psbd902455.jpg
So I pulled the SR and began my part out
http://i803.photobucket.com/albums/y...ps901f3897.jpg
I picked up my F Body LS from a good friend, and is already built, but I decided to freshen up a few things before the season starts.
http://i803.photobucket.com/albums/y...ps9ee88fd0.jpg
Engine Specs.
MS4 Camshaft
Texas Speed Valve train (springs, pushrods etc)
Speed pro forged pistons
LS6 Intake manifold
ARP everything haha..
Fidanza Lightweight flywheel
Sikky Trans mount
Sikky Driveshaft
Sikky Headers
Canton Racing Oil pan
Custom engine mounts
Tuned ECU
and a fully built T56
I decided to purchase..
Wiring Specialties Pro wiring harness
Spec stage 3 clutch
MSD starter
Sikky Fuel filter kit
Mishimoto radiator/fan shroud kit
Fidanza replacement friction plate
and a few pics..
http://i803.photobucket.com/albums/y...psa00cf14f.jpg
http://i803.photobucket.com/albums/y...ps2003d414.jpg
http://i803.photobucket.com/albums/y...ps9480317f.jpg
http://i803.photobucket.com/albums/y...psc963d180.jpg
http://i803.photobucket.com/albums/y...psf91424f3.jpg
http://i803.photobucket.com/albums/y...psf7214de2.jpg
and the current chassis setup..
Tein Super Street Coilovers
Tein Pillowball Upper Mounts
Energy Suspension Master bushing Kit (All bushings replaced)
Energy Suspension Polyurethane Subframe Bushings
ISIS Toe Arms
ISIS Traction Arms
Adjustable Rear Upper Control Arms
Adjustable Tension Rods
Wilwood 12.2” 4POT Front Brake kit (Arizona Z Car)
STRI Electronic Oil Press Gauge
STRI Electronic Fuel Press Gauge
STRI Electronic Water Temp Gauge
http://i803.photobucket.com/albums/y...1/IMG_1143.jpg
http://i803.photobucket.com/albums/y...1/IMG_1091.jpg
http://i803.photobucket.com/albums/y...1/IMG_0960.jpg
I picked up some ARP Flywheel bolts
http://i803.photobucket.com/albums/y...ps34231af5.jpg
I got the new friction plate mounted on the flywheel
http://i803.photobucket.com/albums/y...ps6cfbfc97.jpg
mounted the flywheel and new Spec 3 Clutch
http://i803.photobucket.com/albums/y...psfda2661c.jpg
http://i803.photobucket.com/albums/y...ps3d2482ea.jpg
and then I also put on the new MSD starter (so purdy)
http://i803.photobucket.com/albums/y...psb65c4971.jpg
Then I dropped off my headers Gateway Powder coating to be Ceramic Coated and they look great!!
(not sure why they look silver in these pics)
http://i803.photobucket.com/albums/y...psz9f4mped.jpg
http://i803.photobucket.com/albums/y...pslk1i21jp.jpg
Also picked some some MLS Gaskets as well..
http://i803.photobucket.com/albums/y...psy9713ema.jpg
My Wiring Specialties Harness also showed up
http://i803.photobucket.com/albums/y...ps10871c20.jpg
New plugs are wires
http://i803.photobucket.com/albums/y...psrcs48tqa.jpg
http://i803.photobucket.com/albums/y...pse01ea497.jpg
Badbob2121 Feb 26, 2014 10:55 AM
Steam vent routed to upper rad hose.
http://i803.photobucket.com/albums/y...ps4400c8ae.jpg
I bought the adapter from Jagsthatrun.com
http://jagsthatrun.com/Pages/Parts_Cooling_LSI-tee.html
K&N Filter and Earls fitting in today for my Fuel pressure gauge
https://i803.photobucket.com/albums/...ps2194a26c.jpg
and the finished intake setup
https://i803.photobucket.com/albums/...psc4dba521.jpg
and the Sikky corvette fuel filter/regulator kit with the new fitting in place
https://i803.photobucket.com/albums/...ps263dee93.jpg
Fuel rail
http://i803.photobucket.com/albums/y...psa56e483c.jpg
Since I have to unbolt the steering shaft to install the driver's side header, I figured I would replace that bushing as well. Picked up from Forced Fab.
http://i803.photobucket.com/albums/y...ps2b4618c4.jpg
and all done..
http://i803.photobucket.com/albums/y...ps39199a62.jpg
So I got the sikky fuel kit all hooked up and also put on the new fresh plate welded diff and here's where I finished the day..
http://i803.photobucket.com/albums/y...ps24552793.jpg
The next day
-Both headers are bolted on (PITA)
-Wiring Harness is all hooked up
-Driveshaft on
-fluids filled
-Clutch MC connected
-connected the P/S
I just need to finished up wiring up my electric fans, drop in the radiator, clean everything up and fire her up.
http://i803.photobucket.com/albums/y...ps3f808dc2.jpg
cooks 7 Feb 26, 2014 10:56 AM
very cool! from a fellow St. Louisan/Ls swapper
BoostinIx Feb 26, 2014 11:00 AM
Woo! More 240s on here FTW
Nissan LS240 Feb 26, 2014 08:02 PM
another one.... lol, the LS wont dissappoint, until your diff breaks, then you're sad, but then you get happy again when you put another diff in.
Kaane Feb 26, 2014 08:10 PM
Be careful with those fittings you have on the fuel rail and the regulator, several people had their cars burn down when they popped off. There is a revised version of them with a metal threaded retainer instead of the shitty plastic one.
Old Shitty design
http://www.pro-touring.com/attachmen...9&d=1363890891
New car won't catch on fire design
http://i718.photobucket.com/albums/w...psdae0751d.jpg
2nice2slow Feb 26, 2014 09:05 PM
Changing your License plate..lol?
or
Could just change the meaning to lol i have a v8...or another v8 lol
brewster240 Feb 26, 2014 09:57 PM
Old Shitty design
yes, ive had those blow off my fuel filter. luckily it was mounted under the car and not in the engine bay. i just lost power and pulled to the side of the road.
another thing, flip the fuel rail around so the feed is on same side as filter.
Badbob2121 Feb 27, 2014 09:01 AM
Thank you for the advice, do you have a link to where I could purchase the new filter/regulator with these fittings??
or
I applied for a new plate, and the DMV denied it.. so the current plate will stay. I kinda like the irony.. haha
vannatta20 Feb 27, 2014 06:17 PM
The feed and return ports are wrong the the photos... The outside port is the feed.
Badbob2121 Feb 28, 2014 09:05 AM
Haha, ^^ You're right, but I am still interested in finding out where to buy the filter/regulator with those updated fittings..
lq4powereds13 Feb 28, 2014 11:18 AM
You should be able to use the regulator you have currently. Here is a link to the fitting part numbers. They will be the RUSSELL PUSH-ON EFI FITTINGS (SCREW IN END CAP) ones.
http://www.russellperformance.com/mc...fuel-efi.shtml
Badbob2121 Feb 28, 2014 12:39 PM
Perfect, Thank you! I believe I would only need the 3/8 and 5/16 for the bottom feed/return lines, as the top of my regulator isnt the same as the one pictured.
Kaane Feb 28, 2014 02:49 PM
replace the one on the fuel rail as well.
Badbob2121 Feb 28, 2014 03:04 PM
Luckily I thought about that right before I placed my order.
Thanks again for the info!
Badbob2121 Mar 23, 2014 01:51 PM
Well I received the new fuel fittings and put everything together and it fired on the first try.
Start up video
http://www.youtube.com/watch?v=YEv3JLc916
Fixed a small coolant leak, wired up my E-fans, put on my y-pipe and went for a long drive.
http://i803.photobucket.com/albums/y...ps429174ba.jpg
It is awesome, the MS4 Cam is sooo aggressive, its crazy. Running straight pipe is way too loud for the street, so I had a vibrant muffler welded on, and its much better.
http://i803.photobucket.com/albums/y...ps6d54f6aa.jpg
https://i803.photobucket.com/albums/...psa108b2ed.jpg
https://i803.photobucket.com/albums/...ps74f9b6a1.jpg
and I am registered for the first DriftSTL event this year on April 6th
https://i803.photobucket.com/albums/...pse7c05d82.png
Went out and took some pics with some buddies this Friday..
8 - 6 - 4
http://i803.photobucket.com/albums/y...ps189a2d53.jpg
and yesterday I finally put on the modded knuckles
I also finally put on some PBM Tie rod spacers to help with the extra tie rod length Ill need
http://i803.photobucket.com/albums/y...ps647d1ba3.jpg
I also picked up some High Angle Tension rods
http://i803.photobucket.com/albums/y...ps06216d40.jpg
http://i803.photobucket.com/albums/y...psf5330624.jpg
got angle?
http://i803.photobucket.com/albums/y...pse63f6ffd.jpg
Im going in for alignment tomorrow, but I can already tell how awesome these knuckles are going to be.. cant wait for April 6th
brewster240 Mar 23, 2014 03:57 PM
any reason you didnt flip the rail around instead of looping all that extra fuel line behind the engine?
Badbob2121 Mar 23, 2014 05:02 PM
Because the line that came with the kit I bought was designed to connect on the driver side. I simply didnt feel like cutting the line.. Im satisfied with how it came out.
Badbob2121 May 14, 2014 07:01 PM
The first event with the LS went awesome. It ran great and I had a blast. The power was instant and the knuckles were worth every penny..
a few pics I found..
http://i803.photobucket.com/albums/y...ps7a8ca5fe.jpg
http://i803.photobucket.com/albums/y...psfbd059d8.jpg
http://i803.photobucket.com/albums/y...ps4a8ee905.jpg
http://i803.photobucket.com/albums/y...pse5bd6e96.jpg
http://i803.photobucket.com/albums/y...ps79a838af.jpg
There is a small event next week and another on June 8th.
© 2026 MH Sub I, LLC dba Internet Brands
