waterpump, rad thermostat question Tried doing a search but not much luck. Finally getting to putting a radiator in my project. I have a truck 5.3 , stock water pump. First of all how to I get the hose nipple out of the waterpump without wrecking it, I need to turn it toards the driver side . Also is there other option for lower termostat housings ? maybe one that swivels ? |
Heat the pump at the fitting(not the fitting its self), Then use a piece of pipe inserted into the outlet and turn to the desired position. Allow it to cool and it will stay where you positioned it. Done. Or you could completely remove it, tap with npt and use a nipple or a 90, or a npt to AN fitting to get where you need to be. There is a write up on here about a ford tstat housing that fits but points straight out and another that swivels. |
Sounds good, I will try that. I think I found a swivel housing ($100) was hoping for a junk yard solution Do you remember what that ford housing was? Did a quick search can't seem to find it |
Early ford windstar housing. I've got mine installed with a permadry gasket with the late style ls thermostate that doesn't attach to the housing. I'm still in the process to see if it seals and functions properly. |
Originally Posted by pan58head
(Post 18349778)
Sounds good, I will try that. I think I found a swivel housing ($100) was hoping for a junk yard solution Do you remember what that ford housing was? Did a quick search can't seem to find it https://i248.photobucket.com/albums/...ps25ed9246.jpg Also, you can use car LS waterpumps to give you a different waterpump outlet. I used a 2010+ Camaro L99 pump for a waterpump out on the driver's side of the pulley, that also lines up with the truck accessories. |
Another idea for the outlet is to remove the top outlet, and freeze plug it. Then drill the flat casting out and put your outlet there(Just below the original(LS1 location)). |
Whatever housing you use, do NOT use an old style SBC thermostat. They do not have the extra disk that manages the coolant by pass. What can happen is hot coolant can be pulled right back into the motor without going through the radiator. See my comments on posts 4 and 11 of this thread. https://ls1tech.com/forums/conversio...r-neck-ls.html |
Originally Posted by Stu Cool
(Post 18350860)
Whatever housing you use, do NOT use an old style SBC thermostat. They do not have the extra disk that manages the coolant by pass. What can happen is hot coolant can be pulled right back into the motor without going through the radiator. See my comments on post for of this thread. https://ls1tech.com/forums/conversio...r-neck-ls.html |
© 2024 MH Sub I, LLC dba Internet Brands
