LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Conversions & Swaps (https://ls1tech.com/forums/conversions-swaps-28/)
-   -   Can't Get Scanner to Link (https://ls1tech.com/forums/conversions-swaps/1741298-cant-get-scanner-link.html)
Andy1 Aug 9, 2014 01:25 PM
I get "Data Link Error" on my Acutron scanner. My setup is a 01 Fbody PCM (01 Z28 Camaro 5.7) into a Porsche 914. Car runs fine from the day I first started it, but the OBD2 port never worked. I buzzed out the wires on the OBD2 connector; pin 2 to blue 58, pin 4 to chassis ground, pin 5 to chassis ground, pin 16 to +12V constant.
I read through the previous thread https://ls1tech.com/forums/conversio...r-link-up.html and still can't get a link up. In the previous thread, some suggested that if you run pin 5 ground directly to the PCM ground, it fixed their link up. I ran a ground from pin 5 directly to the PCM ground on the left cylinder head (rear) which is the original 01 Fbody PCM ground location. Still no luck. I don't have a 01 Fbody schematic to see exactly how the OBD2 is wired on the Camaro, but I think I've got it right.
I'm looking for suggestions on where to look next. Any help is greatly appreciated.
Andy1
bczee Aug 9, 2014 02:08 PM
Have you ruled out that the scanner is the issue ? Run down to a shop that scans for free and see if there scanner can connect. Sounds like you have it wired up connect iirc..
Andy1 Aug 9, 2014 02:21 PM
My scanner works on other vehicles. That said however, I have read that some scanners don't work on every vehicles; sort of a random occurrence.
Maybe I'll borrow a different scanner and try it out (Which would simplify my life a whole lot;))
Andy1
© 2026 MH Sub I, LLC dba Internet Brands
