injector problems with 5.3L in 76 nova okay im almost done with my swap! try to do a start up today and the engine is turning over but will never start. i checked the usuals getting spark to the spark plugs, getting fuel to the rail but i cannot get nothing out of the injectors tried chasing some wires with nothing coming back as bad. please help me lol |
Sticking injectors is a very common occurrence these days. If they are stuck, take them out and soak them in Seafoam overnight and reinstall, should do the trick. |
Originally Posted by ls1nova71
(Post 18484116)
I too used LS1nova71's SeaFoam trick. It works!! BTW……… thanks LS1nova71 |
Wasn't my idea, I read it on here a long time ago! But it does seem to work good. |
Awesome, I will get to that tonight. Thanks! |
Have you checked to make sure you are getting a pules signal from the ECM ?, pick up a Noid light to check by connecting it to the harness end and crank it over to see if it lights up or not. You might check the resistance across the injectors two terminals, should be around 14 ohms. You can try the lift the injector/rail off the manifold and raise it up some, place a paper towel under it and then crank the engine over to see if it is spraying or not. Just a few things to check. good luck BC |
will it run on starting fluid ? have you checked to make sure you have constant pluse to injectors ? VATS will let the injectors pulse 3 times and then shuts them down , if while cranking it pluses a couple times and then stops , you have a VATS issue |
© 2024 MH Sub I, LLC dba Internet Brands
