Gto ls2 in '86 Monte carlo ss
I have installed the gm muscle car pan and am just waiting on my cam and associated parts to get here from texas speed. Cant wait to start bolting this thing in! I also opted to purchase a new harness from bp automotive instead of having mine reworked.
I have the stock gto oil pan, alternator and starter to sell now but unfortunately havnt met the criteria to post in the classifieds here yet.
I used the holley set up in my 83 cutlass with 17/8 ceramic long tubes .pulled nose off car .I installed motor and trans in one shot took about 30 min. Headers fit perfect went in nice from underneath. If I were u I would go with holley set up but to each his own.just research everything there are a few combos that work nice killer car
LS1Tech Sponsor
That fuel pump is sufficient even for a cammed engine.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
I got the rest of the engine all wired up thanks to Biil's harness (BP Automotive) Seriously cant say enough about how nice this harness is, and Bills support is second to none. He always answers the phone when I call, and is very prompt about getting back to me with pm's. So glad I bought one of his new harness's vs having mine modified. Just need to finish my cold air intake and hook up my existing 3" exhaust to the new headers. Also waiting on a friend to come tune the car so it will actually start. The injectors arent firing because of the vats on the ecm I believe.
#36
LS1Tech Sponsor
Patiently Waiting! Lol.
That is a sweet ride. That harness tucked right in. Cant see hardly any of it!
Bill
Bill
__________________
1-888-467-4491
1-888-467-4491
#38
Thanks Bill. The harness worked out perfect! I was able to mount the ecm where I wanted to, and the supplied grommet on the harness was a perfect fit for my cars oem hole in the firewall for the factory harness. The only thing thats really visible is the sleek relay/fuse block. I love it!
#40
One of my plug wires pulled apart when removing it. I pullet it off by holding the heat shield around the boot, but the metal clip stayed attached to the spark plug and pulled the wire apart. They are the originals with 75k miles on them so I'm sure it wont hurt to replace them. Would premium napa/auto parts stores wires be sufficient or should I be getting oem delco's/aftermarket?
