4l60 wiring into foxbody
Got a couple of questions about the 4l60 wiring into a fox mustang. Im trying to retain the full electronic control of the trans witht the pcm.
Where would the park neutral switch signal wire from the trans connect to?
Also the neutral safety signal wire from the trans would wire directly into the old fox nss wiring correct?
thanks for any help
thanks for any help
Thanks but ive already traced all the wires i would need. Problem is according to the 00 truck schematic the yellow wire for the switch provides a geound. I tried hooking up to a relay setup but it sidnt work. Whenever i hook thr whitw and pink with the red blue wires the car will wtart any time. Im trying to retain the safety feature. Thanks again
