i need help!!
Old Feb 16, 2016 | 03:23 PM
caldwellsdime's Avatar
Default i need help!!
alright guys ive searched everywhere and cant seem to find a 01 Silverado inside cab fuse box pinout diagram. Im doing a swap in my s10 and took the complete harness cab and motor with all the fuse boxs and everything including all the way up to the key. I cut the wires going to the radio and ac seeing as I wont be using those but now the cluster wont power on the check engine light comes on and a couple gauges move like theyre gonna turn on but nothing else works. also go to start the truck and it fires up then like 5 secs later dies im assuming the security system is shutting it off but don't get y if I have the key.. so someone please help me and yes I know I should just do the cpw harness but don't have the money for it
Old Feb 16, 2016 | 03:40 PM
robm-951's Avatar
You might need to do a security relearn procedure. I found one at the time I did mine, but couldn't remember where. I googled and found this procedure:
Security Relearn
Step 1: Attempt to start vehicle. If it starts up, then no relearn is needed. If it does not start or if it starts and immediately dies, then the relearn procedure is needed.
Step 2: Leave the key in the run position for 10-12 minutes (or until the security light shuts off). Make sure that no accessories are on and that your headlights are switched to the off position.
Step 3: Remove the key from the ignition for 45 seconds.
Step 4: Repeat steps 1-3 three times, ensuring that you attempt to start it on each attempt. On the fourth start attempt, the vehicle should start and the relearn is complete.
Old Feb 16, 2016 | 04:33 PM
okay ill definitely try that but I still need a pin out so I can figure out why the cluster isn't working fully..
Old Feb 16, 2016 | 08:17 PM
CutLS's Avatar
I can get you diagrams. Do you need the I/P fuse block connecter end view or the I/P schematic?
Old Feb 16, 2016 | 10:20 PM
https://ls1tech.com/forums/conversio...rams-here.html
This is what im looking for but for the interior fuse box
Old Feb 16, 2016 | 10:50 PM
CutLS's Avatar
CutLS's Avatar
Sorry I posted them slightly out of order
Old Feb 16, 2016 | 10:59 PM
Oh ure amazing thank u.. ive been driving myself nuts all day to figure out what they were
