LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Conversions & Swaps (https://ls1tech.com/forums/conversions-swaps-28/)
-   -   Ls swap #2 & #4 cylinders won't fire at an idle (https://ls1tech.com/forums/conversions-swaps/1837022-ls-swap-2-4-cylinders-wont-fire-idle.html)
C10 swap Jun 27, 2016 09:14 PM
Swapped a 2002 5.3l into my 1970 c10
And 2 cylinders won't fire at an idle.
I have good compression and running compression.
Good fuel pressure. Have spark at the plugs.
I've moved the coil from side to side still same 2 cylinders don't fire. Move injectors around still same to hole are died. Tryed new o2 sensors no change. New maf sensor still same two died holes. Changed the computer same thing. Any help going out of stuff to try or change. It's always #2 &#4 cylinders. Thanks
1964SS Jun 28, 2016 01:02 PM
If you've swapped injectors and the problem did not move then your next test will be to check for injector pulse at those injectors with a noid light. Sounds to me like you either have a couple injector grounds missing or they aren't getting signal from the pcm.
C10 swap Jun 28, 2016 02:50 PM
Checked with the noid light and that checked out
Good. Thanks anything else
DW SD Jun 28, 2016 02:57 PM
Doesn't really make sense if you are getting injector pulse signal, you've moved injectors around away from those cylinders and have compression across all cylinders.
I have two ideas:
How about vacuum leak(s) at those two cylinders?
Have you pulled those two spark plugs? Perhaps you've got fouled plugs there?
C10 swap Jun 28, 2016 03:51 PM
I've changed plug and moved them side to side also.
I'll check for vacuum leaks now.
Thanks
1964SS Jun 28, 2016 04:40 PM
This doesn't make any sense at all. You said you have spark and now you have injector pulse as well. Fuel, spark and compression is all it takes. What about this harness? Is it possible you have #2 and #4 injector wires swapped so they aren't firing at the correct time?
DW SD Jun 28, 2016 04:59 PM
Good thought.
Or maybe #2 and #4 coil outputs are swapped at the PCM? So they aren't timed right? Can you check timing with a timing light on those two? Firing order and some math will tell you what the offset should be from cylinder #1.
C10 swap Jun 28, 2016 07:42 PM
Have traced the injectors wire back and they are in the right pin spot. Coils next
sowbelle Jun 28, 2016 08:34 PM
Valve springs
sowbelle Jun 28, 2016 08:35 PM
Have you checked valve springs?
C10 swap Jun 28, 2016 08:35 PM
New springs
sowbelle Jun 28, 2016 08:41 PM
Do these cylinders fire off idle and above? How have you determined these
two are not firing?
How is oil pressure? maybe collapsing lifters on those cylinders
sowbelle Jun 28, 2016 08:43 PM
Also did u hear engine running in donor vehicle?
How many miles on it?
IN gear or neutral?
C10 swap Jun 28, 2016 09:54 PM
They are stone cold to the touch at an idle . They build heat when Rev up but still not as hot as the other 6..
No did hear it got for a freind that heard it run. Oil
presure is good.
Thoughts on cam or crank sensors?
truckdoug Jun 28, 2016 10:55 PM
i didnt see plug wires on that checklist, it's an easy test if you didnt already
C10 swap Jun 28, 2016 11:19 PM
Sorry forgot new plug wires and have moved them for side to side too.
truckdoug Jun 28, 2016 11:37 PM
is it throwing any codes?
C10 swap Jun 28, 2016 11:38 PM
No codes either
DW SD Jun 29, 2016 09:14 AM
Did you check actual spark check timing of the two cylinders? Maybe the coil trigger wires are flip flopped from the PCM?
Doug
© 2026 MH Sub I, LLC dba Internet Brands
