240SX Oil Pan - Canton 15-276 or Moroso 20146?
It looks like these two pans are the best choices if you want something that is not outrageously priced (like Sikky). But is either better than the other? I have heard reports of Canton pans leaking. Would the Moroso pan be less likely to leak?
Used this one below with no issues. Also used a Sikky one for my last build cause the guy that sold me the setup had the entire Sikky Swap Package. No issues for me. One difference that was noted but I am not sure if it matters is that the Sikky Pan is designed like the OEM unit where it bolts into the transmission. I read a while back that the design actually adds structural strength but I never looked into it any further. Regardless I had no issues with the Canton unit. The Moroso one doesnt have that portion where it bolts into the bellhousing either.
http://www.enjukuracing.com/products...-ls1-swap.html
