Truck AC unit on High Mount AC conversion in LS SWAP? Hey all, I'm doing an LS swap into an 84 Firebird and I plan on using either Dirty Dingo or LSSimple high-mount brackets to put the AC and Alternator in the stock TPI position. My question is, will the truck AC compressor work in the High Mount location? does anyone know? I found one reference that said it wouldn't because of the pulley position/style but I don't remember where I saw it so I can't find it again. does anyone know? Any help is greatly appreciated before I spend money I don't need to on this truck compressor. |
If you are using the front set of crank ribs then yes, if hoping to use the rear set then most likely not. Edit - just noticed you were talking about stock truck compressor, I was imagining a Sanden like I used. I did see an aftermarket bracket for it the other day but it was low mount which does you no good. |
Truck compressors wont bolt to any aftermarket brackets, and they are only 3 or 4 rib belt where as the main belt is wider so the belt wont fit. I have seen people use the old pancake style of compressor mounted up high. That would be a better solution since thats the compressor your car would have originally had. |
Thanks guys. The LSSimple brackets come with either an R4 style LS1 compressor or a Sanden unit but it's rather expensive. I got a steal on this Truck accessory set but if I don't need or can't use the truck AC unit, I'll tell the guy I can't use it and will hopefully get it even cheaper. |
"R4 style LS1 compressor" :confused: The R4 was (thankfully) dead by the time the LS1 came around. Have lssimple's brackets for the V5 compressor - quality work for the price. Wouldn't go back to a cycling clutch system at any cost. |
© 2024 MH Sub I, LLC dba Internet Brands
