BMW + 427ci 7.0l + full-on build
Old 06-28-2018, 09:53 AM
  #181
Michael Yount's Avatar
I’ve only ever been able to carefully drill successively larger holes until pieces begin to come out and then run a tap through the remaining threads to clean it up. If it’s this tough to get out it’s likely got screwed up female threads any how. As mentioned before can you drill slightly larger all the way through and just use a longer bolt with a nut on the other end?
Old 06-28-2018, 09:58 AM
  #182
MUL8NO1's Avatar
Default No nuts
”up above the threads”... is a shaft that appears to close at top where it’s welded to top side of unibody frame-sonetging
note the pic here
That vertical tube is where my subframe bolt/s go up in to... each of the 4 holes has same type of “enclosure”
Old 07-09-2018, 10:09 AM
  #183
MUL8NO1's Avatar
Default Weeks of works - just one bolt/hole
Welp... the 2 of 2 diamond tip hole cutter eventually got all threads... and tip of bolt that clearly was above the chassis threads released and got pushed up sideways in the hole... in the chassis - uhhhh... time to play Doctor... with myself 🤔
Hole for reverse thread extractor became very off center after 3.5” of drilling blindly up through it. Because bolt has now sheered twice I’m removing this bolt via 1/3rds... and using a diamond tip (2 of them) hole cutter to juuuuust cut up and around threads.
Updates via pictures...
Old 07-09-2018, 10:15 AM
  #184
MUL8NO1's Avatar
Default I should know how to do this... fill the hole buddy
So here is naked hole.
Ready for an insert and a replacement OE bolt.
I watched this video as my final research and made my thread insert choice:
Old 07-09-2018, 10:37 AM
  #185
Wish I had a better sense of where/what you’re drilling. Can’t tell from pics.
Old 07-09-2018, 02:45 PM
  #186
MUL8NO1's Avatar
Default The Where
Front subframe locates left to right via 2 holes in the unibody per side.
The Front left frame hole has the threads which receives the FL subframe bolt.
Im inserting this HeliCoil thread insert up in to the chassis...
Old 07-09-2018, 03:16 PM
  #187
Picture from further away while pointing at the area?
Old 07-10-2018, 07:07 AM
  #188
MUL8NO1's Avatar
Ruined bolt hole under this FL part of unibody
Old 07-10-2018, 07:08 AM
  #189
MUL8NO1's Avatar
Trouble uploading more than 1 pic at a time right now...
Old 07-10-2018, 07:09 AM
  #190
MUL8NO1's Avatar
Default Hole
Old 07-10-2018, 07:10 AM
  #191
MUL8NO1's Avatar
Default 1 at a time
Old 07-10-2018, 07:52 AM
  #192
Last pic - I think I finally understand. Does the bolt holding the crossmember in screw into that from below?
Old 07-10-2018, 10:41 AM
  #193
MUL8NO1's Avatar
Default Si Senor
Yes, the front crossmember locates ‘squarely’ to frame via four ball/socket type shapes that fit in to one another.
Once the crossmember locates squarely to body from underneath an M12x1.5x100 point threads up and positions up through the subframe/crossmember and affixes to the threaded inserts up in the unibody... like a rectangle!!!
Old 07-17-2018, 10:03 PM
  #194
MUL8NO1's Avatar
Default Progress.... road block x 2
3rd cut session on passenger side and still hitting... close tho This is ‘the’ use for my dremel scary cutting when not my small dremel with 1.5” diameter cutting wheel. Time for a trip to Lowe’s 2moro
Subframe up and in now utilizing 4 new big proper bolts and one fresh M12 x1.5 Helicoil - that I’ll torque once subframe/suspension is loaded on ground.
So, it seemed like the one of four frame threads that got ruined seemed like the largest issue possible...
Now with that remedied it was time to install headers - you know, the ones that were custom made over a looooong spans and worked great early this year with the 6.0l. That was with the OE bellhousing -
As I’m finding out the HARD WAY (Pun intended) the Quick Time bellhousing has a much more R-O-U-N-D shape to it... and of course my custom tight fighting headers are bonking away on metal - and not even close to fitting. I began cutting within 5 min of determining the problem - started with passenger side first:
Pics for any crying partners here
Old 07-17-2018, 11:41 PM
  #195
Mark Watney, “The Martian” —- “...you solve enough problems, you get to come home.”
You’ll have it tearing up the track before you know it.
Old 07-23-2018, 12:00 PM
  #196
MUL8NO1's Avatar
Default Close....... er
A corded-dremel tool and plethora of EZ-swap metal disks... Yeah
What’s done is done.
A bolt in a hole. Some holes, when filled, just seem more satisfying than others :-) Now to finagle nut tightening tools on aft side of hole... ... And clean everything back up to my standards.
Driver side Quick Time Bell Housing Mod cut complete - and was actually sufficient to fully install that side header, steering column, engine mount, valve cover, etc
Pass side Bellhousing requires another 3-5mm of grinding in and way, and in a space, where I just don’t have sufficient tools = a Lowe’s visit today may drum up something.
Ive seen movies where inmates used spoons from the lunch room to dig all way through their cell block walls and out to freedom... maybe I can bogart a spoon from Mommas kitchen to satisfy my special tools need!!!
If the spoon doesn’t work on my Bellhousing, I’ll convert it to a shank and stab myself a time or two - enough prodding, and eventually something will give.
Old 07-23-2018, 12:21 PM
  #197
Is that rubber/plastic bellows on the steering shaft going to survive the radiant heat from the headers?
Old 07-28-2018, 05:05 PM
  #198
MUL8NO1's Avatar
Default Truth, Justice, and the Sweaty Progress Way...
A pick of my wiener ... with Mustard
It’s been a solid 6mo since things looked like this...
Welp - still a waste of money thus far
At some point, WITH PROPER OIL PRESSURE, this will run and be amazing.
Side shot - cause everyone likes to hit it from the side every now and then!!!
I still lack a little more clearancing of the Quick Time bellhousing only on the passenger side to allow previous header to clear...
But the driver side is good to go - and trans bolted up, engine sitting In mounts, driveshaft installed, valley pan back on, cleaned work space.
Once header clearance good, I’ll get remaining full exhaust reinstalled and prove to myself that all custom mounts/holes/bolts reassemble as did previously... then I can final torque the main Vorshlag beefy engine mount/arm nuts.
I could have reinstalled the intake manifold and did a 30min re-plug session of all connections to include fuel - but I didn’t need to tease myself to apply power just yet.
Progress pics for cool-pics sake!!!
Old 08-01-2018, 10:19 PM
  #199
MUL8NO1's Avatar
Default Clearance Clarence
Welp... I guess hurrying is just no longer necessary
Dust on the paint is just Not Acceptable
The necessary bellhousing clearancing so headers fit is now complete...
So, a bit of touch up paint to protect metal and then on to hang underside exhaust... then tighten headers and move on to re-plugging connectors and fuel and intake manifold and all front engine items...
Old 08-01-2018, 10:22 PM
  #200
Loverly.
Quick Reply: BMW + 427ci 7.0l + full-on build
