Newly swapped 4L80E wont shift
Old Apr 26, 2018 | 09:47 PM
Snowman1789's Avatar
Default Newly swapped 4L80E wont shift
Hi guys, last year I swapped a cable drive 5.3 into my daughters 83 Chevy K10. I originally used the 700r4 that came with the truck. It lasted about 5 months, then crapped out. So, I decoded to swap in a 2004 4L80E that had been behind a 6.0. I had the tranny fresh rebuild, stuck it in the truck, then took it to my programmer guy. the only shift we can get it to make on its own if a WOT shift from 1st to 2nd at about 40mph. he can shift it manually with HP Tuners, but nothing on its own. I am using the original NP208 with a Dakota Digital pass through VSS and the stock ISS on the 80. Both seem to be reading correctly. Still no shift. I changed the TPS, and the ISS to no avail. any suggestions?
Old Apr 28, 2018 | 12:35 PM
Mr.Bu's Avatar
Is it throwing any codes? Could be shift solenoids in the trans.
