92 Mustang vert LS budget build
hello everyone! Im keith! im new to the forum (any LS forum) , but wanted to sare my LS mustang build! its a work in progress, but I'll get there eventually! the goal is to go 6.5 or less in the 1/8th mile, for less than $5k INCLUDING the car! im already well on my way, and have it all documented on my youtube channel! follow along, and feel free to give advice, comment,or anything else you see fit! (i have thick skin, no worries) thanks yall!!
https://www.youtube.com/playlist?lis...d30LPMdX1ts4_U
6.50 in the 1/8th with c-clips ??....Here at Roush thats a no no.....Also we use double adjustable rear control arms with solid aluminum bushings.....Also your going to wish you had double adjustable rear arms so you can get the slicks in the center of the wheel opening.....With my 28x10.5x15 slicks i only have about .500-.750 per side clearance....if the upper arms where double adjustable then you could set pinion angle vary easy.........if your using a smaller shorter tire you should be fine....
Also what oil pan ?........the truck pans hang to low.......also the cheap muscle car pan hangs to low..........i think you can use the Ls1 f-body pan and maybe the CTS-V pan....maybe..
Also how old is the teamz Ls k-member ?? Good thing your using a th400.....the second one they made a 60e or 80e or t56 don't fit......
Great videos that guys can learn from...good job...
Also
99-04 rear 8.8 is 56.5"
94-98 rear 8.8 is 55"
79-93 rear 8.8 is 53.5"
79-93 and 94-98 use the same length housing but with different axles....
Also
Also
Also
It's not that the Strange splines aren't up to it; the C-clips STILL AREN'T.
ah, gotcha... well if come upon some super cheap eliminators, Ill be putting them on! i dont want yall to think im a know-it-all... I most certainly dont lol. the whole point is to go fast, drive it home, and LEARN!! as they say, BUILD IT-RACE IT-BREAK IT-FIX IT-RACE IT AGAIN-BREAK IT AGAIN lololol.
Teamz has the motor up to high thats why the 3 trans don't fit....some guys are making or cutting the mounts so the motor sits lower...........AJE all trans fit.........Heres some good reading for ya........
https://ls1tech.com/forums/conversio...nce-issue.html
You can also get engine mounting brackets from Hooker that are made for the Team Z K-member that puts the engine in a different position than the Team Z engine mounting brackets do and provides for fitment of 4l60, 4L80 or T56 in the car.
