ThickkSarge's 88 Notch Picked this sucker up back in August. Car was hideous, I needed it. https://cimg2.ibsrv.net/gimg/ls1tech...54733d0e6e.jpg Everyone needs a bolt in 6 point right? https://cimg4.ibsrv.net/gimg/ls1tech...064ce208ad.jpg Everything about this car was trash https://cimg3.ibsrv.net/gimg/ls1tech...7b6c5538b3.jpg Idiot tried pulling it out of a field by the lower radiator support.....sooooo that's gotta go. https://cimg6.ibsrv.net/gimg/ls1tech...d8123babe1.jpg 2 weeks later I picked her up for like $300 bucks and brought her home. https://cimg7.ibsrv.net/gimg/ls1tech...704db79eac.jpg Not really any actual rust, just needs lots of wheel and paint time. https://cimg7.ibsrv.net/gimg/ls1tech...115b69bb78.jpg Started chopping away at all that sound deadening and insulation. https://cimg9.ibsrv.net/gimg/ls1tech...57e8423e86.jpg https://cimg4.ibsrv.net/gimg/ls1tech...245532fcc5.jpg Bare bones now. All body panels are sitting in my basement hah. https://cimg3.ibsrv.net/gimg/ls1tech...413aa1cb0f.jpg After hours with the wheel, hammer and chisel. Got some primer and paint on it. https://cimg2.ibsrv.net/gimg/ls1tech...6b9358e59d.jpg https://cimg6.ibsrv.net/gimg/ls1tech...d50283d01f.jpg https://cimg7.ibsrv.net/gimg/ls1tech...0b13428f4c.jpg Team Z K waiting to be hung. https://cimg9.ibsrv.net/gimg/ls1tech...2b56f9d112.jpg Along with some SN V8 spindles that I need to clean up and re paint. https://cimg4.ibsrv.net/gimg/ls1tech...6740021c63.jpg Is it even a race car if it doesn't have some DA Stranges? https://cimg0.ibsrv.net/gimg/ls1tech...a25558e861.jpg |
doesnt everyone pull cars out of the weeds by the radiator support? cool notchback. what are your plans for it? |
Originally Posted by jeffs55chevy
(Post 20069505)
Originally Posted by booboo37
(Post 20070900)
Did you do a search on teamz Ls k-member ? What transmission ? |
(Post 20070900)
Picked this little iron block up for a couple hundred bucks. It spun over by hand, so that's a good start? https://cimg5.ibsrv.net/gimg/ls1tech...8c11891af0.jpg https://cimg2.ibsrv.net/gimg/ls1tech...e616ddb5d1.jpg https://cimg6.ibsrv.net/gimg/ls1tech...c8b89e2304.jpg https://cimg7.ibsrv.net/gimg/ls1tech...a132231570.jpg https://cimg6.ibsrv.net/gimg/ls1tech...a606585c93.jpg https://cimg8.ibsrv.net/gimg/ls1tech...dad5d00ef7.jpg Doesn't look too bad at all. Just needs some serious cleaning. But it should get the job done. |
https://cimg0.ibsrv.net/gimg/ls1tech...b6f860ce36.jpg https://cimg3.ibsrv.net/gimg/ls1tech...7f7e4e84c7.jpg https://cimg5.ibsrv.net/gimg/ls1tech...8434ce659e.jpg https://cimg8.ibsrv.net/gimg/ls1tech...3cdd44df6e.jpg Cut out that torn up lower radiator support, most likely the whole front from the shock towers forward is coming off. Got the trunk floor out of the way to be able to start framing out for the cell and battery before putting the new floor down. And the minitub project has began. Got plenty of work to do on that though. |
If you run into any of those issues using the combination of the Team Z K-member with their engine mounting brackets, you can resolve them by using the Hooker Blackheart LS engine mounting brackets specifically made for that K-member. |
[QUOTE=booboo37;20072186]
Originally Posted by ThickkSarge
(Post 20071159)
Picked this little iron block up for a couple hundred bucks. It spun over by hand, so that's a good start? Just because the crank spins over don't mean that it don't have a spun rod or main bearing.......I use to take apart bad warranty Ls motors.....I was surprised at all the spun bearings and how easy the crank spun.. |
(Post 20072176)
If i remember right a 4L60 and a 4L80 and a t56 don't fit.......motor sits up to high and some conversion headers don't clear the steering shaft.... Did ya do a search on the teamz Ls k member before suggesting a search on the teamz Ls k member to verfify what you think you read? Sorry man, but that is just funny and I could resist being a smartA$$ :) |
Listen to Boo Boo37, he’s the Mustang LS oil pan police, he’ll tell you what you can and cannot use. |
(Post 20072176)
If i remember right a 4L60 and a 4L80 and a t56 don't fit.......motor sits up to high and some conversion headers don't clear the steering shaft.... |
Thinking bout ordering some caster/camber plates and some A-Arms this week, get the front of this car on the ground finally. Any input on A Arms? Mostly adjustable vs non and stock length or narrowed. I really think I need the adjustables, mainly for the heim joints. But I keep going back and forth between stock length and 1" shorter. |
Great progress~ |
Think I want to clean up this motor and start getting the heads back on soon at least. May do some ebay head studs and LS9 head gaskets. Gotta figure out a pan. |
No better way to go than with a F-Body oil pan. I was going to try to shorten my truck pan but was going to lose about 1.5-2 quarts of oil doing so. I just picked up a pan myself from a member here so I can get my engine installed in my 84 Mustang GT. |
I shortened a truck pan. I had a Holley pan to measure when I did it so it would hold the same amount of oil as long as you re marked the dipstick. The tray inside the pan is nearly in the same place in both pans. I ended up having to get the newest style Holley pan as I am using a stock subframe and truck front drive. |
| All times are GMT -5. The time now is 05:42 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
