Conversion advice sought
Old Mar 25, 2022 | 06:10 AM
JeffFro's Avatar
Default Conversion advice sought
I am in the process of building a vehicle real similar to the XR311. Will be powering it with a 2014 L83 and a 6L80 with a manual shift Dana 300 transfer case.
My questions that I have as of now are:
1. With using the E92 ecm, are there any ecms batch numbers that are easier to program than the others?
2. The 6L80 is from an 08 Pontiac G8, will this TCM be able to be flashed/programmed to work with the 2014 L83?
3. When I got the motor, it was a pull from a truck without the ecm and wiring harness. Other than the "shift on the fly" wiring for 4x4, are there any differences between the 2wd and 4wd wiring harnesses?
4. The L83 will get the AFM/DOD delete and possibly the VVT delete as well, undecided on the VVT at this time. Which software is the easiest to do this with?
Thanks, appreciate the help.
Pic for reference.
