From v6 to ls1( what is needed wiring wise)
Old Jan 12, 2023 | 12:19 AM
drift_z28's Avatar
Default From v6 to ls1( what is needed wiring wise)
I have a base model f body 4th gen and a z28 model. I am trying to convert my v6 to ls1. What is required wiring wise to make my ls1 work in the base model. Would it be wiser to swap the entire harness over or to only splice the necessary wire to make it work. Also would it require for me to swap over the under dash harness as well or would that not be needed. I would greatly appreciate some pointers and clarification for this swap thank you
Old Jan 22, 2023 | 03:09 PM
the_merv's Avatar
Veteran: Air Force
Do you know how to read a schematic and a pin diagram?
