Manual Swap SUBURBAN
Old Jan 31, 2025 | 06:59 AM
sowaidi's Avatar
Default Manual Swap SUBURBAN
2002 GMC Suburban 2500 6.0 4WD – NV4500 Manual Swap Thread (Not a Yukon XL!)
Hey LS1Tech,
I’ve been working on swapping an NV4500 5-speed manual into my 2002 GMC Suburban 2500 6.0 4WD, and I figured I’d document the process here. There’s not much info on manual swaps for these GMT800 Suburbans, so hopefully, this helps anyone considering it.
Background:
  • This isn’t a Yukon XL—in the Middle East, the Suburban name was used until 2007 before switching to Yukon XL.
  • It’s a 2500 series, factory-equipped with a 6.0L Vortec (LQ4) and a 4L80E.
  • After replacing the fluid in the 4L80E, I noticed slipping when hot, likely due to the previous owner never changing the fluid. Instead of rebuilding, I decided to go manual.
The NV4500 Swap:
I sourced an NV4500 5-speed manual locally from a 2006 GMC Sierra 2500HD. It’s a solid trans, fully synchronized, and torque-rated for heavy-duty use.
Parts Used:
KB Diesel Steel Clutch Pedal – Retains a factory-style pedal feel with a stronger, more durable build.
Tick Performance Master Cylinder – Their newly released 99-06 GMT800 master, designed for better engagement and clutch feel.
OEM NV4500 Bellhousing & Shift Tower – Sourced from the same donor truck.
Video Documentation:
I’ve started a YouTube playlist documenting the swap, with more videos coming soon. Check it out here:
📺 [YouTube Playlist Link]
Initial Impressions:
  • The shifter feel is great—shorter throws than expected, solid engagement.
  • Clutch pedal feel is smooth, thanks to the Tick master cylinder.
  • No more worrying about 4L80E heat issues or slip—this thing shifts crisp.
I’ll update this thread with more details, driving impressions, and any challenges along the way. If you have any questions or want to see anything specific, let me know!
Would love to hear from anyone else who’s done a manual swap on a GMT800 truck or SUV!
Old Feb 3, 2025 | 07:07 AM
LQ4-E39's Avatar
Cool conversion, do you do any towing?
Old Feb 6, 2025 | 07:09 PM
Full Power's Avatar
What are axle gear ratio ?
What is your first gear ?
Do you normally start in second gear ?
I guess you would have had to cut off part of the OEM Brake pedal ?
What is the driveshaft length difference ?
