TRUCK motor for 68 Camaro convertible
I found a deal(?) on a 5.3 motor and automatic transmission combo at my local performance shop. A 2002 model with just under 14,000 miles for $2500 complete. Until yesterday, I had never really considered this conversion. Can you give me some advise before I cut a check?
Specifically:
1. What mods are needed to "wake up" this 5.3? (new intake, heads, cam...)
2. Is the 5.3 swap similar to the LS1 conversion? (motor mounts, oil pan mods...)
3. I REALLY want a T56 six-speed in place of the automatic. Will this screw up the computer or wiring harness set-up?
He also has a new 6.0 motor at the shop. Not sure on the price, but would this be a better choice for a few dollars more?
I'm a newbie when it comes to conversion, so any and all advise is appreciated.
Specifically:
I would hold out for the 6.0 motor. If it has the iron block, then it can be bored out and can be hot rodded easily to 500hp. There are some differences in the PCM's for the T56, but I believe not a big issue going from auto to t56. More of an issue going from t56 to automatic PCM. Overall, it would be exactly like the LS1 swap. I am currently trying to talk a colleague of mine into the 6.0 swap into a shoebox Chevy.
The more I read about the 6.0, the more I like the idea. Would definitely need to get rid of the "big ugly" intake on the truck motor. I assume that an LS1/LS6 intake and covers would be direct bolt ons.
(Off topic to 67LS1 - Great pictures of your ragtop! What size Hopsters and tire combo?)
LS1Tech Co-Founder
don't spend that much on a 5.3L. You should be able to find an aluminum LS1 for that price. I wouldn't buy any smaller than a 6.0L truck engine.
As far as swaps, the truck 4.8/5.3/6.0 engines are basically LS1s but with iron blocks. All of the parts are interchangable. If you get a 6.0, make sure it is one of the newer (2000+) types with the aluminum heads. The older ones had cast iron heads.
Tony
Tony
Originally Posted by Scream
The intake manifold will physically bolt up to any 4.8/5.3/6.0, but the truck's idler pulley will be in the way....
According to the other post, Speartech offers some bracketry to get around the idler issue. But what about water pump routing?
The outlet on the waterpump points up on the trucks and faces straight out on the F-body one, and the "bell" on the truck pump is threaded for an engine-driven fan. Also, the car accessories are closer to the block than the truck accessories (something like 5/8").
The 6.0 also comes in two versions, and maybe even three. The most common one is 300 hp, and the HO version is a 345 hp. I think there is also a 325 out there. I'm not sure if it's the ecu, the intake system, or something internal, such as cam or compresion difference. I have 5 of these new 6.0's and several other Gen 3 motors that I'm going to be doing conversion's on, and I really need to start learning more about these. If anyone knows any links that will give tips on what ecu to use, and what wiring harness is best, I'd appreciate it.
I'm going to do a conversion on an 04 model Chev short bed, regular cab, as these are the nicest driving trucks out there.
ps, the price on the 02 model 5.3 complete power train, 15,000 miles, at $2500.00 is not high. And I would like to see you find a 5.7 complete powertrain with those miles for anywhere close to that. Not a chance of that.
Skip White
Skip White
Skip White
Skip White
Also, I bought my LS1/4l60e with 34,000 miles for $2000
