bell housing???
this board is such a great help, so much info, thanx guys!
I just test fit a new Lakewood blow proof #15005 to my LQ4 fit good except for some minor grinding near the top of the block for the nut on the block plate. This may not be an issue with the aluminum block LS1 & LS6. It also comes with a machined adapter that presses into the back of the crank to use a standard pilot bushing. Instead of the adapter and bronze pilot bushing I used a GM pilot bearing #12557583 which is a sealed ball bearing , everything fits perfectly and it cost less than $10.00 . Much less than some dealers want for the adapter to use the old-style bushing. This bellhousing even has a bracket on it so I can mount a bracket for my clutch cross shaft. This bell will ONLY bolt up to Muncie,Borg Warner T-10 , Doug Nash , and other transmissions with the old style bolt pattern.
see pic here: https://ls1tech.com/forums/showthrea...99#post1413799
i've got a super t-10. if i bolt that onto my ls1 engine and put the transmission back in its original spot where will the engine sit. can i use those s&p motor mounts?
see a pic of the solid style here:https://ls1tech.com/forums/attachmen...chmentid=10335
Stan
