91 swap Q's
thats the only way i had the cash for the LS1.
You then plumb using regular AN-06 hardware to the regulator, rails, and return line.
or do what i did and plumb a vette regulator/filter in the back, and have some lines made... (do a search for it with my username)
The Vette regulator/filter back at the tank...
The Earl's AN-06 adapter at the engine compartment hard line...
This allows me to use generic off-the-shelf AN-06 hardware in the engine compartment, and a generic off-the-shelf Vette regulator/filter in the back.
Custom-made hoses make me nervous when it comes time for emergency replacement, I'm just paranoid that way.
i love the way i have it now. its like a OEM setup and any needed repairs can be made with a off-the-shelf OEM line repair kit..... however, the vette filter/regulator is not manifold refrenced... and im now moving on to boost.... somthing i wasnt doing before.
once i reach the limit of the injectors im either going to have to step up to much larger injectors, or redo my fuel system.
athough from the sound of it, you arnt plannin on boost, so either way is fine.
