ls1 rx-7, won't fire, help I think I have gone over everything, but I still get no spark, vatts deleted by hp tuners, pink @ coils have 12v, black @coils have good ground, fuel pump primes. I pulled the plugs out and they look wet, so I am pretty sure I have fuel, but just no spark at the plugs. I tried grounding the ref wire at coils, still no luck. I am puzzled, I checked the crank, and cam pos sensors, and the signal wires both made the meter jump around when the other probe was grounded so I think they are working. It isn't pulling up any codes. HELP! |
Sounds like the crank sensor is not picking up a signal, but thats a wild guess at this point. Check all fuses and connections. Double check the VATs too. |
check your grounds again! when i did my swap, i some issues just like yours and it was because of a ground |
Alright, after piddling with this thing for hours, I ran a wire from the battery straight to the coils, and bumped the key, it fires right up. I can take the wire away that is ran to the battery, and it will stay running. I had the coil power, and pcm power all wired together on a switched circuit that went to the rx7 stock pcm, It powers on the ls1 pcm, fuel pump kicks on, and meters 12v at the coils, but won't start. I am going to rewire some stuff tommarrow, and run a seperate wire from the battery to a relay then to the coils, hopefully that will get it working right, Thanks for the help. |
This happened to me- make sure the 12V you have going to the fuel pump, PCM, and coils is energized when the key is in the "start" position. Hopefully that fixes is for you. Ben
Originally Posted by 12thstreetjunkman Alright, after piddling with this thing for hours, I ran a wire from the battery straight to the coils, and bumped the key, it fires right up. I can take the wire away that is ran to the battery, and it will stay running. I had the coil power, and pcm power all wired together on a switched circuit that went to the rx7 stock pcm, It powers on the ls1 pcm, fuel pump kicks on, and meters 12v at the coils, but won't start. I am going to rewire some stuff tommarrow, and run a seperate wire from the battery to a relay then to the coils, hopefully that will get it working right, Thanks for the help. |
I had a similar problem with my RX7 swap. Connecting ALL the loose pink wires in the LS1 harness to ignition "run" fixed it. |
rx-ben, you hit the nail on the head, the wire I had used for the pcm and coils didn't have 12v while cranking, so I would hear the pump prime, crank with no power, then let of the key back to on position and have power to everything doh :bang:. Now I just need to get my headers flanges in and I am on the road! |
good to see you figured it out! |
| All times are GMT -5. The time now is 02:17 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
