TH350-VSS how many pulses
Old Jun 17, 2005 | 05:18 AM
GTS346's Avatar
Default TH350-VSS how many pulses
I need to buy an Inline Speed Sensor or Vehicle S/S which ever you prefer to call it.
How many pulses does the factory Delco PCM's require? As the aftermarket VSS come in anything from 2-150 pulses per rev.
Old Jun 19, 2005 | 03:40 PM
TJ's Avatar
TJ
what ecm are you running?
what instrument cluster are you using?
these are the factors that play a huge roll.
ill help if i can.
Old Jun 20, 2005 | 11:26 PM
01WS6/tamu's Avatar
If you are using a short tail 350 it will have the large diameter sender hole. You can then use a reluctor and sender from an 88 up 700r-4 from a fullsize truck. That is how we made it all work on my monter carlo when I put the vortec 350 in. I needed elcetric out for my autometer speedo.
Old Jun 21, 2005 | 02:09 PM
Bigdeezs's Avatar
Not absolutely sure but I think the 4l60e behind my 2000 ls1 uses 40 pulses.
