ls1 in s2000? I've had my s2000 for a while now and was wondering what options i had in gaining power (mostly torque since its almost not even existant lol). I just stumbled onto this site and found that ls1 swaps have been done in many different cars and the one that surprised me the most was the v8 miata :hail: I was wondering if this swap is possible in an s2000? any imput would be nice thanks |
Theres tons of room under the hood of a s2000. I say go for it. Mock the engine up in there to get the factory weight distrubtion(or better) and it should be one hell of a beast! -Matt |
if ur gonna do it u may as well do a stroker and make it insanely fast. 383 in an s2000...destroy anyone? |
It can be done. Major modification will be the K-frame. Might even be able to use a modified Miata kit for the install. Re-enforcing the body & a proper suspension are a must. Unless you are willing to modify the rear wheel wells, it won't be a drag car (can't fit wide enough tires for the launch). No car is unbeatable & now with GM's LS7, the advantage of having a V8 Miata or a V8 S2000 has been all but eliminated. Also will tell you that 400-450 RWHP & 450 #-ft of RW torque is about the limit for usable power in a Miata or S2000. Believe me, I speak from experience. Often wonder what guys in F-bodys & Corvettes do with 900 HP on the street. The power craze has almost gotten out of hand. Bottom line is build it & you'll love it. For sure you won't lose many races. Good-luck & let us know if ya go for it. |
This isn't an LS engine, but I tried to talk my freind into dropping this into his S2000. http://www.powertecengineering.com/images/v8eng.jpg It's 2 Hayabusa engines made into a V8 http://www.powertecengineering.com/v8_index.php 383 HP and 207 ft. lbs of torque. 10,500 RPM redline |
That's cool. The S2000 idea because I'd been thinking it myself, and that Powertec Hayabusu V8 is pretty sick as well. |
Yeah....Hayabusa....that thing is sick. |
Originally Posted by Dragula This isn't an LS engine, but I tried to talk my freind into dropping this into his S2000. 383 HP and 207 ft. lbs of torque. 10,500 RPM redline That's a cool idea. Although, the 207 ft-lbs won't come close to the feel of an LS1. Aftermarket heads & a moderate cam will yield 400/400 + in an LS1 engine (stock will give ya 350 #-ft w/headers). Good torque is needed to move all that front end weight or else she feels like it takes forever to gain speed from a stop. Gotta have the torque. You could also get around 325/225 + with a good turbo kit without adding front end weight. |
i looked around and i couldn't find how much the engine would cost for that hayabusa engine but having 10k rpm is wicked though... i did some research and found that the f20c engine is mounted in the bay longitudinally. does the ls1 engine mount up the same way? |
Originally Posted by lilboi735 I've had my s2000 for a while now and was wondering what options i had in gaining power (mostly torque since its almost not even existant lol). thanks Good Luck! Mike R. |
That busa hybrid seems almost inefficient considering that you can get 550hp out of a built and turbo'd single hayabusa motor. I'm running a twin turbo ls1 w/750rwhp on the street and can't get enough. Right now I'm doing weight reduction to attempt 3000lbs and do a cam and methanol for 900rwhp on the street. Should be pretty wicked! I say go for the ls1/s2000 swap. |
Why not forge your current engine and run 15+ pounds of boost (turbo/supercharger)? That will net you 500+ rwhp w/o the hassle of changing engines etc. |
Originally Posted by lilboi735 i looked around and i couldn't find how much the engine would cost for that hayabusa engine but having 10k rpm is wicked though... i did some research and found that the f20c engine is mounted in the bay longitudinally. does the ls1 engine mount up the same way? http://lhtperformance.net They do any and all Honda stuff. I like the turbo Insight. |
there is one running around DFW, Tx |
This video from Streetfire just popped up on our local message board today...is this the car in DFW? Any other details on the car? http://videos.streetfire.net/video/E...23CCCB8701.htm |
Originally Posted by Scream This video from Streetfire just popped up on our local message board today...is this the car in DFW? Any other details on the car? http://videos.streetfire.net/video/E...23CCCB8701.htm |
I say go for the LS-2000. I plan to do the same in a couple years when I can find an S2000 for hella cheap
Originally Posted by 93formto98T/A That busa hybrid seems almost inefficient considering that you can get 550hp out of a built and turbo'd single hayabusa motor. |
© 2024 MH Sub I, LLC dba Internet Brands
