altenator power wire
Old Apr 13, 2007 | 11:26 AM
69blackwidow's Avatar
Default altenator power wire
do you think it will be a problem if i run 2 power wires off my altenator. batt is in the trunk, i have one power wire run to a terminal block under my dash to power fuse block then back to batt. would like to put a terminal block on the rad support for fans and headlights with relays mike
Old Apr 13, 2007 | 12:33 PM
bczee's Avatar
I don't think it will be a problem, many of the older cars I have seen many people have taped in to the junction terminal for other equipement.
I have a direct (Racetronix setup) power feed tapped off of the alternator to my Fuel Pump relay.
Old Apr 13, 2007 | 08:44 PM
G-Body's Avatar
sawzall wielding director
Running more than one wire off the alternator will not be a problem at all.
