conversion pic's and questions 2003 5.3 with 4l60E Questions: can I run regular fuel line for the return back to the tank? the heater hoses that come off the water pump, is one an out and the other a return, or whats up with them? how do you run a mechanical oil gauge? anyway here are some pics of the motor swap and other "up grades" http://i97.photobucket.com/albums/l2...n/PICT1053.jpg http://i97.photobucket.com/albums/l2...n/PICT1054.jpg http://i97.photobucket.com/albums/l2...n/PICT1055.jpg http://i97.photobucket.com/albums/l2...n/PICT1056.jpg http://i97.photobucket.com/albums/l2...n/PICT1057.jpg http://i97.photobucket.com/albums/l2...n/PICT1058.jpg http://i97.photobucket.com/albums/l2...n/PICT1059.jpg http://i97.photobucket.com/albums/l2...n/PICT1060.jpg http://i97.photobucket.com/albums/l2...n/PICT1061.jpg http://i97.photobucket.com/albums/l2...n/PICT1062.jpg |
Originally Posted by orangefun 2003 5.3 with 4l60E Questions: can I run regular fuel line for the return back to the tank? the heater hoses that come off the water pump, is one an out and the other a return, or whats up with them? how do you run a mechanical oil gauge? Yep, the nipples on the waterpump are the in and the out for the heater hoses. I forget which is in and which is out. To run a mechanical oil pressure gauge you will need metric to american adapters, autometer and equues(sp?) make them. Remove the factory sending unit from behind the intake and then install the adapter and the mechanical pickup. |
| All times are GMT -5. The time now is 11:37 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
