LSX Fox
I need more room on the passenger side just behind the steering rack mount.
I have a truck pan and swapped that on , somehow managed to get it to clear the stock kmember going in (though taking it out is going to be a b%^&*) and now have enough room it seems.
I do have a couple of questions:
I am concerned about not being able to get the engine to sit low enough with the truck pan, more precisely as low as the motor will allow ( for hood clearance) as the truck pan is thicker on the front and will contact the steering rack sooner.
So I can go with a moroso pan whose sump is a little over an inch shorter, may or may not work.
It would appear that I really should purchase a tubular k member .
I really like the maximum motorsports k member but I have not seen anyone use it in a swap yet. Has anyone tried that?
How much clearance have you guys left between the fire wall and the back of the block in your setups?
I am running a ls1 with a mcleod bellhousing and a tko 600, vic junior and holly 750 uptop.
Also it appears that the 351 swap longtubes will not clear on the pass side, anyone have any pics of their setup in a fox?
thanks for the help in advance
Jamie
so you recommend the qa1?
I like the idea of retaining factory a-arms and coil springs, I was not aware that theirs would do that.
does it have as much clearance as the AJE and UPR?
I have the upper and lower and will weld them together once I have it sitting where I want it.
I just want to make sure I can get to the back of the motor if I need to, and I am trying to retain near factory length on the drive shaft as well.
are you able to get to everything you need in your setup?
also the qa1 k member supposedly moves the wheels forward and inch and some and out an inch and some.
How did that affect your steering rack?
Jamie
this does seem to be a pretty good solution to my problem, I really would like to retain the f body oil pan
do you feel that the qa1 has held up pretty well and are you using it on the street?
1. Simplicity -- you can modify a stock motor mount and the motor just drops in.
2. Revised geometry -- I like the 4.6 angles better, even if that means adjusting a few things.
I had to extend my steering shaft to reach the rack, using a 5.0 rack. My 5.0 tie rods reached, but barely. I'm going to swap them so I feel more comfortable -- I want plenty of threads in there. Tires fit just fine on my car and didn't rub, but some people say they had clearance issues at the front.
brains, you said there are better angles on the 4.6, are you referring to the steering geometry and wider track of the 4.6 stuff?
I wonder if anyone(penny pincher) has considered using a stock K member from a 4.6 mustang?
Yes the '99 up one will work.
But has anybody actualy used a stock one rather than a tubular? Every single fox projects I have seen on this forum use a tubular K-member. I'd like to try using a stock one but I dont want to have to buy one and find out later on that it doesnt really work. I know it seems like I'm asking twice but I prefer asking twice and buying once if you know what I mean.
