T56 driveline vibration
Now with all that said, 4.5 degrees (1 to 2 degrees is ideal) is still a lot of angle, just about the end of what most u-joints are designed to handle without vibration. So even if you get the rear end fixed up, you may still have some vibration at higher driveline speeds. You'll have to try it and see.
Good luck,
John Parsons
What I do not understand is that if I measure the angle at the T56 yoke end from the top of the ujoint bearing cap to the top of the driveshaft I get 4.5 degrees, if I measure from below I get around 1 or 2 degrees. Shouldn't they be the same?
Andrew
http://www.chevytalk.org/threads/sho...&fpart=all
I had the same problem when I put my motor in the car and engine did not looked centered so I had to gring the manifold and put O2 sensor on the egzost and now engine is centered and there is enough clearence manifold to steering box. By the way i used S&P motor mount adapters and have iroc steering box.
Good luck
